d15/d16 question
Old Oct 5, 2006 | 02:34 PM
b16hatchyo's Avatar
Default d15/d16 question
i was wondering , i believe i can do this but i just want to make sure..
i have a stock d15b engine in my 92 coupe, can i take out the d15 block and head, and replace it with a d16y8 head and block with the stock tranny? if i just change blocks and heads will it bolt up??? question may sound dumb but i wanna be 100% shure... thanks
Old Oct 5, 2006 | 02:47 PM
lemon_juice's Avatar
Default Re: d15/d16 question (b16hatchyo)
so basically you want to swap out your entire d15b for a d16y8?
if you had another question that mentioned that i sort of caught...yes, those 2 motors can mis-match heads and blocks also. you need to figure out the wiring tho, depending on what youll be doing
Old Oct 5, 2006 | 02:59 PM
knockout's Avatar
do a search under minime / mini-me / mini me. either of those three will yield tons of threads covering your question.
Old Oct 5, 2006 | 03:03 PM
Syndacate's Avatar
Default Re: d15/d16 question (knockout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout &raquo;</TD></TR><TR><TD CLASS="quote">do a search under minime / mini-me / mini me. either of those three will yield tons of threads covering your question.</TD></TR></TABLE>
He might have a VTEC d15b in which case it's not a mini-me setup.
@ OP:
The heads are interchangable. May need re-wiring or something or different ECU I don't know. Though mechanically you can put the Y8 head on it.
Old Oct 5, 2006 | 03:06 PM
knockout's Avatar
Default Re: d15/d16 question (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
He might have a VTEC d15b in which case it's not a mini-me setup.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hatchyo &raquo;</TD></TR><TR><TD CLASS="quote">
i have a stock d15b engine in my 92 coupe</TD></TR></TABLE>
Old Oct 5, 2006 | 03:11 PM
92ehatch's Avatar
i think what he is asking is if his tranny will bolt up to a d16y8
if that is it, then yes. d series trannies are interchangeable
Old Oct 5, 2006 | 03:26 PM
b16hatchyo's Avatar
Default Re: d15/d16 question (92ehatch)
yah its a VTEC D15b ....i think i got my answer though....thanks for the help!!
ekadehdmau5!!
Feb 16, 2012 05:37 PM
VTECboy97
11
Nov 11, 2007 04:26 PM
Otherguy
Feb 13, 2005 04:59 PM
