LSD needed for turbo?
Ima run 8psi on a td05 or 04? dont remember which its has slightly higher trim then stock wrx turbo tuning with vafc2 and i got 3 bar
i was told with h22 or h23 tranny all ima do is spin tires without lsd that true?
Personally i believe in doing it right or not doing it at all. But if I was you id say ditch the afc rather than getting lsd. Run some type of ems. LSD you can always do in the future and it will not affect maps or anything. Just dont run from a stop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">ive seen many people use VAFC and be fine its only 8 psi i can always upgrade later</TD></TR></TABLE>
wake up and smell the coffee. Turbo tuning is based mostly on tuning the timing, which a vafc cannot do. racing around on a vafc, your motor will EVENTUALLY blow up. Just a matter of time.
moesrex
Feb 23, 2006 10:16 AM
Snafu-Si
Feb 3, 2002 03:10 PM
