technecal question about oil pump
Old Oct 5, 2006 | 09:50 AM
hany's Avatar
Default technecal question about oil pump
does the pressure of the oil pump increase by the rbm or it consider fixed pressure at any rbm in the honda ?
__________________
Old Oct 5, 2006 | 10:38 AM
EK-Chris's Avatar
Default Re: technecal question about oil pump (hany)
rpm= revolutions per minute NOT rbm
Yes oil pressure increases as rpms increase.
Old Oct 5, 2006 | 03:26 PM
hany's Avatar
Default Re: technecal question about oil pump (EK-Chris)
thank you alot for answering
Old Oct 5, 2006 | 03:29 PM
EG2Driver's Avatar
OP, you probably know, but the crank runs it. The faster the RPMs go, the faster it'll pump.
Just in case......cause ur still a noob.
Old Oct 5, 2006 | 04:00 PM
Crazydave's Avatar
Default Re: technecal question about oil pump (DeadEnd9009)
There is a pressure relief valve though too.....
so I would imagine that the pressure would not stop climbing
Old Oct 5, 2006 | 05:20 PM
nighttrain33's Avatar
Default Re: technecal question about oil pump (Crazydave)
At high rpm's, many oil pumps tend to drop pressure slightly. Other than that, the pressure gets higher with rpm's.
-Shane
93turbo16
Jan 30, 2006 06:03 PM
paulITR
Dec 3, 2003 06:33 AM
ImprtTuner88
Oct 16, 2002 04:56 AM
