what is the minimum compresion ratio reguirement for the motor to start over and run( like shit)
Old Oct 5, 2006 | 08:59 AM
urafag's Avatar
Default what is the minimum compresion ratio reguirement for the motor to start over and run( like ****)
wats the minumum compresion under which the motor will still tart over but run like ****? is it 70? 50? 25?>
Old Oct 5, 2006 | 09:46 AM
89 civic si's Avatar
Default Re: what is the minimum compresion ratio reguirement for the motor to start over and run( like ****)
it depends how great the numbers are beetween eachother ive seen hondas run with a hole in the block running on 2 pistons. i think unless the motor is hydrolocked or there are holes in every piston the car should start with just 2 cylinders
Old Oct 5, 2006 | 10:21 AM
urafag's Avatar
damn,
i recently had a starting problem with the zc i have in a crx.
the car is geting spark, and it is geteing gas, but doesnot want to start!!!
Old Oct 5, 2006 | 11:18 AM
Got_soy's Avatar
Default Re: (urafag)
i think 130 was rebuild limit in the manual
Old Oct 5, 2006 | 01:25 PM
E_F_9's Avatar
maybe your timing is off
Sassafrass
Feb 17, 2003 12:47 PM
shermanyang
Aug 5, 2002 12:42 PM
