VSS Plug wire location issue.
Old Oct 5, 2006 | 03:52 AM
enigma94's Avatar
Default VSS Plug wire location issue.
In the middle of my swap i accedentally forgot to unplug the VSS when i dropped the motor and it pulled the pins out of the plug and now i have no idea what order they go in.
There is a black wire, blue/yellow and black/yellow. With the clip part facing up what order do these wires go into the plug?
Already searched but most of the VSS wiring issues had to do with the cluster, which is not my problem...
The way i tried it first was, from left to right with the clip part facing upward : Black, blue/yellow, black/yellow and it still throws a cell and nothing on the speedo.
Any help would be appriciated because im stuf in safe mode till i get this figured out!
Old Oct 5, 2006 | 03:03 PM
enigma94's Avatar
Default Re: VSS Plug wire location issue. (enigma94)
upp
Old Oct 5, 2006 | 03:06 PM
philosofy1's Avatar
pick up a repair manual, in the back of the book. there you can find the wire diagram you're looking for.
Old Oct 5, 2006 | 03:15 PM
gotboostedvr6's Avatar
there are 9 different combos just try them all
Old Oct 5, 2006 | 04:02 PM
enigma94's Avatar
Default Re: VSS Plug wire location issue. (gotboostedvr6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboostedvr6 &raquo;</TD></TR><TR><TD CLASS="quote">there are 9 different combos just try them all </TD></TR></TABLE>
Hahaha, sadly, i thought of this as my only option.
I know there are the diagrams in the back of the helms and such but i dont want to waste the money just because of one plug
I was hoping somebody had the diagram already or knew which wires went where...
Old Oct 5, 2006 | 09:00 PM
enigma94's Avatar
ttt anybody?
Old Oct 6, 2006 | 01:51 PM
enigma94's Avatar
well by trial and error I figured out the wire location on the plug for anybody that runs into the same issue as me.
with the clip to the top it goes from left to right : black, black/yellow, blue yellow.
mugencivic94
Aug 22, 2007 05:33 PM
Mr. LS VTEC
Oct 25, 2006 01:36 AM
teler86
May 24, 2006 09:32 PM
BIG DAVE
Oct 24, 2004 12:31 PM
EK22snatch
17
Aug 7, 2004 09:20 PM
