GSR ECU For A H22A?
Gsr Ecu
I have a 96 prelude and its obd2. I was thinking about converting it to obd1 and use a gsr ecu.
Would a 96 and up gsr obd2 ecu work just as well as the obd1.
Also what kind of gains/loss in torque should i expect and would it help me at all in the 1/4 mile.
A GS-R ECU runs dangerously lean on an H22a. The a/f ratio that results is unsafe to run a motor on. You will need some additional way to tune the fuel delivery and dyno tuning time with a wide-band a/f meter if you want to use that ECU.
Andrew
Andrew
Also, I believe that the 96 Prelude model, although it was OBD2, still had the peak and hold injectors... You can tell by looking for the resistor pack on your injector harness. If it's present, you have peak and hold. If this is the case, this will also be a problem, as the GS-Rs all use saturated injectors.
Andrew
Andrew
remember the gsr ecu was meant for a 1.8 liter combustion chamber and as such, will only inject enough fuel for that size. that ecu with a 2.2 engine is not a good idea.
here is your answer
http://www.importreview.com/reviews/PreludeECUtest.html
and you decide...but gsr ecu is not recommended
dennis
dennis
i'm using gsr hondat setup and its running fine i change my vtec point to 5500
and this ecu kick ***! i told the guys from hondata to change my injector duty cycle to open up a lil longer than stock so rite now its running fine no pinning noise. i'm still waiting for my injector to come int (rc340cc)
