Legend/NSX brakes
Old Oct 4, 2006 | 10:19 PM
lude98SH's Avatar
Default Legend/NSX brakes
Ok i read the thread and im alittle confused. In a 5th Gen when you upgrade you must change the caliper and bracket but do you have do change the rotors ? Also what pads will you now be used NSX/Legend pads or prelude pads ? Lastly will NSX/Legend rear calipers fit ? (i know they do very little breaking i was just wondering)
Old Oct 5, 2006 | 06:09 AM
TruNinja619's Avatar
Default Re: Legend/NSX brakes (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Ok i read the thread and im alittle confused. In a 5th Gen when you upgrade you must change the caliper and bracket but do you have do change the rotors ? Also what pads will you now be used NSX/Legend pads or prelude pads ? Lastly will NSX/Legend rear calipers fit ? (i know they do very little breaking i was just wondering) </TD></TR></TABLE>
since you have a 5th gen... you just stick with the VTEC size rotors you would normally use... so no.. you don't have to change the rotor to a different size that is...
the 2nd question... they should fit... but I think its just a complete waste of time and money doing so... you might end up finding that its almost the same (don't quote me on this).... the brake upgrade was ment for the front.... so yea..
Old Oct 5, 2006 | 08:05 AM
petern101's Avatar
Default Re: Legend/NSX brakes (TruNinja619)
actually it would be the same. read the brake article that was posted on here (maybe in faqs now i don't know)
basically the legend / nsx swap is only for ppl who don't have vtec sized brakes and/or want SOME weight savings. and only the nsx calipers will do this. dual piston might not always mean better braking.
Old Oct 5, 2006 | 08:07 AM
ludeboi121's Avatar
i myself is running on nsx calipers, you will need vtec rotors or perhaps legend rotors. for the front caliper you will run the nsx piston with the prelude bracket, they will bolt right up. pads i suggest you upg those but you will be fine with any oem or aftermarket prelude spec brake pads. Lastly it would be useless to change out your rear, dont even bother.
Old Oct 5, 2006 | 08:10 AM
lude98SH's Avatar
Default Re: Legend/NSX brakes (ludeboi121)
So was it worth the money ?
Old Oct 5, 2006 | 02:43 PM
hu's Avatar
hu
Absolutely this mod is worth it. Nice difference vs. stock at high speed.
Old Oct 5, 2006 | 04:22 PM
petern101's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Absolutely this mod is worth it. Nice difference vs. stock at high speed.</TD></TR></TABLE>
sure it wasn't a fresh set of pads / recently bleed system?
[QUOTE=racerx]Legend/ NSX brake swap: This was long thought to be the factory big brake setup. In fact both have less caliper piston surface area than the factory 4th or 5th gen Preludes. This means less brake torque(see source at bottom) These calipers do have a benefit over stock in that the NSX clampers are a lighter alu alloy and both move the brake bias rearward some. Just swapping the calipers is not worth the trouble for most. You could add the Legend GS’s thicker rotors on your 5g for added brake heat capacity. Since the brakes were designed for a car 600lbs heavier than the Prelude’s, they can withstand a bit more heat. The rotors would have to be redrilled with a 4x114.5 bolt pattern to be used on the 4g or the 5g knuckles swapped in.
[QUOTE]
quoted from the faqs. i would say mimimal gains
Old Oct 5, 2006 | 07:02 PM
Mykizism's Avatar
Default Re: (petern101)
[QUOTE=petern101]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
quoted from the faqs. i would say mimimal gains</TD></TR></TABLE>
real world vs online banter you decide.. i have gs calipers they rock my world when i hit 190 mph.. then again im ditching them for stop tech's soon
Old Oct 5, 2006 | 08:52 PM
king_me's Avatar
I have a 96 si, and was lookin for a subtle way to upgrade my brakes without the huge bright color expensive **** out there. would nsx brakes work on a 4th gen as well?
Old Oct 5, 2006 | 09:17 PM
InvaderTrax's Avatar
Yes, but you'll need VTEC rotors
Old Oct 7, 2006 | 08:19 AM
my9thtry's Avatar
Default Re: (InvaderTrax)
powerslot has a 12 inch rotor and caliper relocation kit for 450 that where my money would be spent if you think youll need more the oem with some kick *** pads. spend you money on a set of high performance pads first.
Old Oct 7, 2006 | 05:58 PM
Toanz's Avatar
which year legend calipers fit?
Old Oct 7, 2006 | 06:14 PM
user 9782082308's Avatar
Default Re: (Toanz)
Actually, I need to revise that. 96-up Legends have the thicker rotors but they're also 1.8cm larger in diamiter. This may or maynot become an issue. The 95-96 Legends that got the twin pot calipers have the same part # as the 5g Ludes.
nubs
May 9, 2006 05:06 PM
NirVTEC
Feb 15, 2006 08:06 PM
IA93Vteclude
Mar 30, 2004 02:56 PM
kotetu
May 30, 2003 10:00 AM
bb6h22a
Mar 11, 2003 10:08 PM
