88' crx hf rear bumper support work w/ my 91' crx dx?
Old Oct 4, 2006 | 08:17 PM
wfocrx's Avatar
Default 88' crx hf rear bumper support work w/ my 91' crx dx?
I have heard that people just remove the rear bumper support. I was just wondering if it would be worth it to use a 88' hf rear support. How much weight would you save? it should fit fine?
Old Oct 4, 2006 | 10:50 PM
KillSwitch's Avatar
Default Re: 88' crx hf rear bumper support work w/ my 91' crx dx? (wfocrx)
how would the rear bumper stay on without a support?
Old Oct 5, 2006 | 09:03 AM
fuccarlos's Avatar
Default Re: 88' crx hf rear bumper support work w/ my 91' crx dx? (thomasbalaci)
hell ya man hf or just cut yours all up so there is just the bare minimum of material left you could probably save up to 10-15 pounds on just the back bracket alone
Old Oct 5, 2006 | 10:14 AM
Tyson's Avatar
yeah, the HF rear bumper support is only 5 lbs. the Si/DX is a good 25lbs. so it is a good 20lbs DIFFERENCE.
the major difference is all the reinforcement in the middle. its otherwise the same, and just sheet metal which makes it so light.
Old Oct 5, 2006 | 10:17 AM
Timmah!!'s Avatar
My HF support was all bent up in an accident... So I took it off and fabricated on out of small aluminium I beams... sorry... no pics.
Worthless if I get rear ended, but it holds the bumper cover in place
rexracer626
10
Feb 10, 2010 07:21 PM
92integracer
Sep 25, 2009 01:08 PM
russianswty
Nov 13, 2006 12:36 PM
axionm1k
31
Sep 28, 2006 05:06 PM
