Need help wiring jdm headlights for a conversion
I posted a request for a tutorial on a jdm conversion for my integra around a month and a half ago and receved very good results which were very helpful.
So now my front end is welded on and pieces fit perfect...though I had to do some slight mods for certain things to work.
Now I'm stuck at the headlights. I've already managed to do the low beam and turn signals(side markers I think I can just buy the harness from passwordjdm), but I'm trying to do the wiring for the high beams, city lights(?), and fog light.
I bought it with the wire bracket thingy(the 5 pin plastic piece that plugs into the headlight unit). ALso mine is not HID. I read the original instructions for the conversion which included the "how to" put the panels together along with a brief instruction on headlights.
Unfortunatly I'm not that car electric savvy. I've printed out a description on which wire does what, but I'm stuck to the point on "how do you wire it". I've been looking around trying to find some pictures on what people have done to their headlights(non-HID). Prolly my main concern is the high beam...do i need to splice wires, or do some kinda mod(had an idea on it) because since the plug would be exposed.
Please help.
ALso if anyone also knows where I can buy a GSR motor +tranny...ecu...etc. So far the cheapest I found is $2500(to be picked up)
Please help.
for the high beams you should be able to take the power lead from your old high beams, and that's it, since all the lights share a common ground. For the foglights you need a relay and a switch, there is a good diagram on here somewhere. I just did my hid install, and I believe it's similar. When you search type in jdm foglights, and it should pop up. As for the city lights, you're on your own.
I have two diagrams on my computer, but don't know how to post them, send me an IM with your email and I'll send it to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMtransformer »</TD></TR><TR><TD CLASS="quote">im stuck too. who wants to make $5 and tell me n this guy how to wire this up. ill pay you threw paypal.</TD></TR></TABLE> nm i got it hooked up myself
vestalfootball72
11
May 10, 2006 05:25 AM
