Stubborn head bolts
Old Oct 4, 2006 | 02:14 PM
InvaderTrax's Avatar
Default Stubborn head bolts
Anyone have any tips for removing stubborn head bolts? I tried a breaker bar as well as an impact driver (not impact gun)
Old Oct 4, 2006 | 02:26 PM
nonvteclude's Avatar
Default Re: Stubborn head bolts (InvaderTrax)
ya they are a bitch, you need to use a breaker bar with alot of force or an impact gun. best with alot of torque in it
Old Oct 4, 2006 | 02:28 PM
I wasn't sure if the impact gun would be likely to snap the bolts. I'll give it a try
Old Oct 4, 2006 | 02:29 PM
v4lu3s's Avatar
RTFM
i would recomend a longer breaker bar and NOT to use an impact gun, when they are really stubrron it is too easy to round the bolts out....done it a few times already and thats a real pain then.
Old Oct 4, 2006 | 02:31 PM
Default Re: (v4lu3s)
those bolts are really strong, if you use a good quality socket that fits right you wont round it off
Old Oct 4, 2006 | 02:44 PM
I've been using a 6 point socket, so it's not likely to round off. Impact gun at 100 PSI woulnd't move them. I'll see if I can dig up a pipe and try and move them
Old Oct 4, 2006 | 04:50 PM
SteveoBA8's Avatar
Default Re: (InvaderTrax)
1/2 breakover bar should do the trick.
Old Oct 4, 2006 | 05:25 PM
hondabigblock's Avatar
Default Re: (SteveoBA8)
you just need to quit being a little bitch j/k
Old Oct 4, 2006 | 06:16 PM
Well, I put a 2 foot pipe over my breaker bar and had my dad hold the block while I pulled on it, and we managed to get them all out without breaking any off
Old Oct 6, 2006 | 06:28 AM
v4lu3s's Avatar
RTFM
thats the way to do it. thogh i often start with a 24 inch breaker then add a 24+ inch pipe to it. crack each one then use the impact gun.
i have seen rounded head bolts off with 6 point Mac, Matco, SK and Snap On sockets before specially with high power impact guns. Its because the amount of toque can make the gun jump unless you are strong/heavy enough to not let it, but whent he gun makes 650ft/lb that can often be hard.
Tong.Y
32
Feb 1, 2011 02:05 PM
jyracer
Jan 13, 2009 08:10 PM
Captain Kyle
Feb 16, 2006 08:30 AM
RACEPAK
Oct 7, 2005 11:08 AM
grngsr01
Jun 15, 2004 07:14 PM
