what head gasket you using?
Old Oct 4, 2006 | 02:13 PM
Takymoto's Avatar
I'm a Jackass
Default what head gasket you using?
What kind of headgaskets are you guys using.. I gotta get one .. just wondering what you guys are going with
Old Oct 4, 2006 | 03:13 PM
chasemyhonda's Avatar
B A N N E D
OEM or Felpro Right here. Ive had 3 Cometics and all 3 of them were leaking
Old Oct 4, 2006 | 03:44 PM
stockb18c's Avatar
OEM all the way
Old Oct 4, 2006 | 04:14 PM
civic_hatch's Avatar
Were do people get 2ply and 1ply HG? Or do they just peel a layer off an OEM one? Not thread jacking just felt it would be relavent in the thread.
Old Oct 4, 2006 | 04:39 PM
B A N N E D
if you wanna run a 1 layer gasket then use the middle layer.
if u wanna run a 2 layer headgasket then remove the middle layer
Old Oct 4, 2006 | 06:01 PM
Takymoto's Avatar
I'm a Jackass
Default Re: (blindingxenon)
any more ? felpro? anyone using this
Old Oct 4, 2006 | 06:06 PM
C1CRX's Avatar
Traffic signal tech
OEM. the second person to post said he used felpro. of the bad things i have heard of cometic i have hear A LOT more good things about them so later on the road when i need a different sized HG i will probably go with a cometic.
kevmugen's Avatar
Default Re: (wOrd!)
OEM
Old Oct 4, 2006 | 06:15 PM
B A N N E D
i like the felpro. seems to be as good as qaulity as OEM headgaskets.
One thing i do is always wash down the gasket with soap and water and let it dry while im removing the head. to be sure everything is clean and that there arent any flaws in the gasket.
Old Oct 4, 2006 | 09:01 PM
fmrprojects's Avatar
OEM with copper spray
Old Oct 5, 2006 | 10:08 AM
B18cHatch06's Avatar
Default Re: (fmrprojects)
oem 2-layer
Old Oct 6, 2006 | 09:33 AM
Takymoto's Avatar
I'm a Jackass
Default Re: (B18cHatch06)
ok.. i took your guy's suggestions in to account.. and bought a spoon lol
Old Oct 6, 2006 | 01:55 PM
DonF's Avatar
Default Re: (wOrd!)
An over-priced OEM, way to go, yO.
Old Oct 6, 2006 | 02:43 PM
-Darren-'s Avatar
Default Re: (wOrd!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wOrd! &raquo;</TD></TR><TR><TD CLASS="quote">ok.. i took your guy's suggestions in to account.. and bought a spoon lol</TD></TR></TABLE>
whats the benefit of using a spoon head gasket??
aslo, did it come with a sticker??
Old Oct 6, 2006 | 07:24 PM
Takymoto's Avatar
I'm a Jackass
Default Re: (-Darren-)
it actually raises compression a bit..
Old Oct 6, 2006 | 08:29 PM
-Darren-'s Avatar
Default Re: (wOrd!)
yeah, i checked it out a little bit after i posted my question.
Old Oct 6, 2006 | 09:55 PM
GSRCRXsi's Avatar
cometic. no problems here
Old Oct 7, 2006 | 11:44 AM
GsR92HaTcH's Avatar
i have a spoon on mine so far no probs with 12.1 comp
Old Oct 7, 2006 | 11:56 AM
allm0torGSR's Avatar
Default Re: (GsR92HaTcH)
A head gasket is a head gasket. Get the one that puts you at the compression you want.
I use OEM for my 12:1 B18C1.
Old Oct 7, 2006 | 06:01 PM
NA_B18C1's Avatar
Default Re: what head gasket you using? (wOrd!)
i am currently using the mugen 2ply HG on my built 12:5 cp gsr engine but motor not swapped in the car yet. anyone had problems using them before? or oil leaks on them before?
Old Oct 7, 2006 | 07:21 PM
91SiZ6's Avatar
Default Re: (allm0torGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allm0torGSR &raquo;</TD></TR><TR><TD CLASS="quote">A head gasket is a head gasket. Get the one that puts you at the compression you want.
Holy thread lube, Batman!
Old Oct 7, 2006 | 07:51 PM
dinko's Avatar
Default Re: what head gasket you using? (NA_B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">i am currently using the mugen 2ply HG on my built 12:5 cp gsr engine but motor not swapped in the car yet. anyone had problems using them before? or oil leaks on them before?</TD></TR></TABLE>
uhh im runnin one and no problems so far. 1,000 miles on the motor.
Shoulda went OEM tho...$140 for a 2 layer Mugen...I learned my lesson!
Old Oct 7, 2006 | 11:23 PM
strsi's Avatar
Default Re: what head gasket you using? (dinko)
mugen
Old Oct 8, 2006 | 09:18 AM
acydphryck's Avatar
4 layer custom OEM setup
Old Oct 8, 2006 | 12:07 PM
Big Teggie's Avatar
Cometic with copper spray.
