OEM Slave players....need pics of back of units..
Old Oct 4, 2006 | 12:37 PM
MestizoRacer310's Avatar
Default OEM Slave players....need pics of back of units..
Both cd and tape slave unit pictures needed.....primarily rear...both "gray plug" and "blue plug" pics wanted...I want to daisy chain off one of the slave players to my Alpine changer...
Old Oct 4, 2006 | 03:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: OEM Slave players....need pics of back of units.. (MestizoRacer310)
All you need is the Honda to Alpine adaptor... http://www.soundgate.com/index...rer=1&
What is the MMY of car? 94
Old Oct 5, 2006 | 01:50 PM
Default Re: OEM Slave players....need pics of back of units.. (fcm)
Thanks man. I already have that adapter. What I'm trying to achieve is pretty much the same as the 6th Gen accord OEM double din CD/tape player. It lets me hook up a CD Changer on top of having the single load CD in the dash....
Old Oct 5, 2006 | 05:30 PM
fcm's Avatar
fcm
Old Fart
Then you have what you need, the "slave" CD or tape player is connected to the HU, [main unit] with an 8 pin din plug I believe, there is also a female 8pin din, panel mount changer control port, [plug] on the back of the "slave" unit, an Alpine changer, with din cord, will plug into the adapter and the adaptor will plug into the slave unit, or you could just remove, [if it's a two piece double din] slave tape player and plug the adaptor, [and Alpine changer] directly into the HU.
Is there a reason why the above will not work, it should be plug and play, or am I missing something? 94
Old Oct 6, 2006 | 05:46 PM
Found out it'll only work if I utilize a CD head unit w/ a tape slave player....I have one from a CL but it gets static-y and the damned drive doesn't work at the moment. It gives a PEO code....
coolharry
Dec 30, 2013 04:58 PM
jdmboyef9
18
Jan 29, 2012 11:09 PM
98cdmej6
Audio / Security / Video
Sep 4, 2011 07:58 AM
quirarte626
Sep 12, 2009 10:11 AM
cxSHOE
Mar 3, 2004 09:06 AM
