MINNESOTA garage sale. teg eg, ek, universal
Old Oct 4, 2006 | 11:27 AM
Bakeoff's Avatar
Default MINNESOTA garage sale. teg eg, ek, universal
Help clean out my garage. If you don't like the price, make an offer. It's all seperated by application.
88-91 civic/crx-
CRX Si rear garnish $10
PM8 CRX Hf ecu $5
PM5 CRX/Civc DX ecu $5
PM6 Ecu $30
B series into EF mount kit $200
B series shift linkage for EF with shifter $20
CRX dash clock with pigtail $5
CRX door handle surround – gray $1
Del Sol/EG-
Del sol rear speaker brackets $5
D series non vtec valve cover $10
EG/DC upper A arms $10
EG driver’s side airbags $10 each? Make an offer
EG stock shifter $5
Del sol window switches $15 for the pair
D series starters (5spd) $20
Del sol front speaker covers $5 each
EG/DC Megan racing H brace with some scuffing on bottom $30
Del sol seats with grey stripe $150
D16z6 stock cam with gear $10
Top half of D series Chikara torque step header $10 (you can use the stock d16 bottom half with this)
D16Z6 crank pulley $5
Del sol rear licence plate panel.. needs paint $20
Del sol front fenders $30 each
Del sol rear window $10
EK Civic-
OBX axle back for coupe $40
d- series shift linkage with shifter $20
Integra-
B series vtec spark plug wire cover-carbon faker $10
PR4 OBD0 LS ecu $30
P75 OBD1 LS ecu $40
2G teg front brake calipers $10
Ls oil pan gasket new in box $10
3G Teg LS front brake calipers $10
DC map light $5
Integra LS cable tranny with genuine Quaife diff. $750
OBD0 teg axles $40 for the pair
1 gsr fat 5 w/ bald tire $15
2g teg factory option center arm rest $40
Prelude-
PK2 88-89 prelude Si 5spd ECU $10?
Universal-
Atari Joystick and Pole Position (that’s right, bitches. Atari!) $5
1 Sparco Speed seat with Jacquard fabric
Daytime running light kit (wiring and relays) $5
Synapse missing link for TB mounting $25
4 205/50 R 15 Kumho ecsta supra 712 tires.. partial tread Make an offer
4 215/40 r 16 kumho ecsta supra 712 tires… partial tread Make an offer
2.5 inlet universal muffler.. FART CAN $30
2x 15 inch computer monitors $15?
Post a reply if you want, PM me for my number, whatever. I want it all gone soon!
-James
Old Oct 4, 2006 | 03:02 PM
Bakeoff's Avatar
bump.
eghatch9295
Sep 4, 2010 09:13 AM
superdelsol
Jun 7, 2007 06:52 PM
