Cant get into 4th at all help
Old Oct 4, 2006 | 11:13 AM
AcuraIntegraLS-T's Avatar
Default Cant get into 4th at all help
I just got my car running again and i picked up a gsr lsd tranny off ebay. It has a spoon sports lsd and was just put together and said to have never been ran. I got it in and i did some 8's to break it in then i went threw all the gears to find it verry hard to get it into the gears and impossable to get it into 4th. i tried shifting into 4th without the clutch just the rpms and still no luck. Anyone have any ideas about what it would be let me know. im thinking like a bent shift fork. But i dont know. Also if anyone knows someone who can work on honda trannys let me know. I dont know how much money i'm looking at but if anyone knows of a ball park to expect i would like to hear it thanks so much.
Old Oct 4, 2006 | 12:01 PM
one slow coupe's Avatar
Default Re: Cant get into 4th at all help (AcuraIntegraLS-T)
Is it getting locked out of gear you mean?
I had a similar problem when I rebuilt my tranny where it would not go in 2nd, 3rd, or 4th..
The actual thing that conects to the shift forks was broken and not lining up right and allowing it to into gear..
hope this helps?
Old Oct 4, 2006 | 02:57 PM
DeadVet's Avatar
Default Re: Cant get into 4th at all help (one slow coupe)
Does it grind when you try to put into 4th? Sounds like the clutch needs to be bled. Try putting it in reverse if it grinds then bleed the clutch and try again.
Old Oct 4, 2006 | 06:27 PM
Dogginator's Avatar
Daisy... Daisy...
Can you shift easily with the car not running?
Old Oct 5, 2006 | 05:41 PM
it moves into the position of 4th but it will grind and push away twords 3rd. It wont shift without using the clutch so i dont think its the clutch thanks for the ideas im pulling it tomorrow and i will see what it is. Any other things i need to know let me hear them ive never had a tranny rebuilt or even seen inside of one so i could use all the help on this that i can get thanks
Hobkins
Transmission & Drivetrain
10
Apr 25, 2009 03:32 PM
RexShop
Nov 24, 2007 09:01 PM
Lude@Heart
May 2, 2004 10:51 AM
