Car wont start and clutch wont disengage 91 civic wagon
Old Oct 4, 2006 | 10:46 AM
Solscud007's Avatar
Default Car wont start and clutch wont disengage 91 civic wagon
ok this car is jsut falling apart on me left and right.
I was driving and I felt the slightest click in the clutch pedal. I was in neutral, engine on and I cannot shift into gear. it was like shifting into a wall.
I turned the car off and now I cant turn it back on. I think the clutch is not disengaging.
Some people said it could be . . .
1. throwout bearing
2. release fork
3. cable
I am new to working on trannies and clutches so please help me out and explain. thanks. I need this car to drive. everything is stock.
Old Oct 4, 2006 | 11:20 AM
T3T4H22's Avatar
Default Re: Car wont start and clutch wont disengage 91 civic wagon (Solscud007)
Its common for the cable to break more than likley thats what happened. It only take a few min to replace.
Old Oct 4, 2006 | 11:29 AM
Solscud007's Avatar
Default Re: Car wont start and clutch wont disengage 91 civic wagon (T3T4H22)
I will check the cable. is there somethign i should look for? I was thinking of having my girl get in and press the clutch pedal ip and down and while I check over by the tranny and the other end of the cable to see if it is moving.
Old Oct 4, 2006 | 12:29 PM
89 civic si's Avatar
just look by the tranny and see if its broke if its broke you will see it, most likely it is your clutch cable any updates?
Old Oct 4, 2006 | 05:18 PM
Solscud007's Avatar
Default Re: Car wont start and clutch wont disengage 91 civic wagon (89 civic si)
ok i had my girl step on the clutch pedal. I can see the clutch cable move and pull the bracket it is attached to upwards. nothin appears broken. so what else could it be?
Old Oct 13, 2006 | 05:34 AM
Akiraboy's Avatar
I believe it may be the throw out bearing
Old Oct 13, 2006 | 05:58 AM
Loserkidwac's Avatar
Default Re: Car wont start and clutch wont disengage 91 civic wagon (Akira_)
Try adjusting the clutch cable its possible it may have streched and dosen't pull enough to dissengage the clutch...I'd say try swapping in a new cable just to see...its a lot easier than dropping the trans...also look under neith at the cluch peddal see if the bracket has cracked...after these checks you may want to drop the trans and take a look inside
fcjohnny
10
May 23, 2009 02:57 PM
speedfreek128
10
Mar 28, 2008 07:45 PM
1SIKEF8B20VTEC
Oct 5, 2005 04:44 PM
G2_Fella
11
Jul 6, 2005 03:08 PM
mizziiiike
13
May 26, 2003 11:33 AM
