RSX code 1167
Old Oct 4, 2006 | 09:16 AM
EG35PSI's Avatar
Default RSX code 1167
I think the heater element is out in my O2.I threw a OBD2 reader on it and it says code 1167?Does any one know that code for the base model RSX thanks
Old Oct 4, 2006 | 09:29 AM
Miracle's Avatar
Default Re: RSX code 1167 (EG35PSI)
You are right about the o2 sensor, that P1167 is a code for the PRIMARY o2 sensor. more than likely a replacement should take care of that problem. If a replacement does not fix it, then its in the wiring, or possibly in the ECU itself.
More than likely just a sensor though.
https://honda-tech.com/zero...32160
http://www.honda-acura.net/for...04916
On the K20A3, the primary sensor sits right ahead of the cat converter... you can get a new one from http://www.hondaautomotiveparts.com for about 190 bucks from what I am seeing.
it is #17 in the diagram above.
Old Oct 4, 2006 | 07:01 PM
EG35PSI's Avatar
Default Re: RSX code 1167 (.Red.EM2)
thank you ....... Ya thats is what I thought because the code would come on in the morning but not when the motor was warm..COOL.. I'm getting the replacement.
Old Oct 4, 2006 | 07:08 PM
Miracle's Avatar
Keep us updated.... this may get added to the FAQ thread, because it seems to be a common problem.
bogdanm
Nov 15, 2016 08:39 AM
dbb95ex
K Series
Mar 5, 2014 03:12 PM
Bozo_JDM
Nov 20, 2008 08:21 PM
typesnick
Feb 4, 2008 09:28 AM
K20EG
Nov 28, 2003 08:10 PM
