5 Speed Gears
Old Oct 4, 2006 | 04:26 AM
susieq's Avatar
Default 5 Speed Gears
I have a 1992 Honda Accord EX 85.000 miles. all of a sudden all the gears are almost impossible to shift and when you put the gear in reverse it makes a whistle like sound. As the car warms up it's not as difficult to shift but still a struggle.
Thanks for any help!
Modified by susieq at 5:37 AM 10/4/2006
Old Oct 4, 2006 | 11:13 AM
hondadude's Avatar
Default Re: 5 Speed Gears (susieq)
Be sure the clutch master isn't leaking fluid under the dash, check for action at the slave/clutch arm. Be sure that someone didn't put 80-90w oil in the trans.
Old Oct 4, 2006 | 11:16 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: 5 Speed Gears (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Be sure the clutch master isn't leaking fluid under the dash, check for action at the slave/clutch arm. Be sure that someone didn't put 80-90w oil in the trans.</TD></TR></TABLE>
Old Oct 4, 2006 | 11:22 AM
susieq's Avatar
Default Re: 5 Speed Gears (MooGoCow3)
Thanks for replies. Just got it checked and the brake fluid which is clutch fluid also, had a small leak has been repaired and all is well.
dragan322
Transmission & Drivetrain
May 27, 2013 07:23 PM
atmusicman85
Apr 18, 2008 06:21 PM
crxgator
Oct 14, 2006 11:46 AM
KloC 95 EG
Mar 13, 2006 09:18 PM
lude98SH
Feb 5, 2006 12:07 PM
