how did your ls/vtec turn out?
ight so im building ls/vtec and i have ctr pistons and gsr head, now my buddies r telling me that it wont work it will blow! so i wanna know if anyone on here has done this setup. all other ls/vtec setups are welcome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie »</TD></TR><TR><TD CLASS="quote">ight so im building ls/vtec and i have ctr pistons and gsr head, now my buddies r telling me that it wont work it will blow! so i wanna know if anyone on here has done this setup. all other ls/vtec setups are welcome
that advice from your buddies is the best you can get
</TD></TR></TABLE>that advice from your buddies is the best you can get
Check the compression here:
http://www.zealautowerks.com
and you'll realize he's right. Oh, there's like 12345678098765 LS/VTEC setups if you look for them.
Guest
Posts: n/a
It'll work, just make sure you have your ecu tuned, and your timing where it should. I am running and LS-VTEC setup with a Eagle stroker kit installed. That is a 81mm x 95mm with SRP 12.1 compression. It is my daily driver, I would just retard the timing for the time being, until you can get it properly tuned. I am running a stock fuel setup, with a p72. Gets great gas mileage and good driveability. Just make sure to get a Type R oil pump. that is the key.
Make sure you get it tuned. My car runs great, no detonation whatsoever.
oh yeah CTR pistons and a GSR head is a proven combo
for insanely high compression and detonation GL with that
https://honda-tech.com/zerothread?id=1634768
in this day and age everyone should know by now. ls/vtec is not any less reliable then any other build, as long as the person who put it together knows what they're doing. Too many rookies get in over their head and put things together with out the proper knowledge or parts.
frank. i have told you a million times. lsvtec + ctr pistons + gsr head = ~13.5:1CR
why cant you understand that this simply is COUNTERPRODUCTIVE with 91 octane cali **** fuel?
at this point pal, do what ya want. run 14.2:1, slap it together and drive to whitfields to get it tuned. just dont call me when it comes apart in yucca valley. call brad.
see the guy running p30s? see everyone and their mother running either p30s or jdm itrs? there is a reason. CTRs are even a tad bit much for an 87.2mm gsr crank, but people make it work for pump gas. but...89mm crank...no.
and that head is a 92/93, its 13+ yrs old...who is to say its never been milled .020''? that make for one rad 14:1+CR 91 octane motor.
slap it together frank. see how it runs since you dismiss good information that you just dont want to hear, in favor of **** information that coincides with your "plans"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kiniku Chunks!!! »</TD></TR><TR><TD CLASS="quote">It'll work, just make sure you have your ecu tuned, and your timing where it should. I am running and LS-VTEC setup with a Eagle stroker kit installed. That is a 81mm x 95mm with SRP 12.1 compression. It is my daily driver, I would just retard the timing for the time being, until you can get it properly tuned. I am running a stock fuel setup, with a p72. Gets great gas mileage and good driveability. Just make sure to get a Type R oil pump. that is the key.
Make sure you get it tuned. My car runs great, no detonation whatsoever.</TD></TR></TABLE>
perfect. so the guy with the 12:1 motor is telling the poor kid with the 13.5:1 motor "itll be fine with tuning"
NO. stop with the misleading bullshit honda-tech info. have a great day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">oh yeah CTR pistons and a GSR head is a proven combo
https://honda-tech.com/zerothread?id=1634768</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">Check the compression here:
and you'll realize he's right. Oh, there's like 12345678098765 LS/VTEC setups if you look for them.</TD></TR></TABLE>
and notice the 2 guys above who have good running set ups are running
1. P73(itr)
2. P30(b16a2)
2 pistons i mentioned while standing out in front of autozone ricing it up last night. p30 has a little more dome, but still streetable. im goign to use RSmachines P30s in my 2 literblock in a couple weeks.
just remember, jump on honda-tech, and within 10-12 posts someone will probably tell you what you WANT to hear, and the result will be a bucket of bolts.
1. P73(itr)
2. P30(b16a2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote"><FONT SIZE="5">Boom!</FONT>
That is all.</TD></TR></TABLE>
x10 in the morongo basin
<buzzards circling>
<buzzards circling>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kiniku Chunks!!! »</TD></TR><TR><TD CLASS="quote"> Just make sure to get a Type R oil pump. that is the key.
si/gsr/r oil pumps are the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">"type R" oil pump
LOLZ ...another classic h-t old wives tale.</TD></TR></TABLE>
LOL thats like saying "YOU NEED MORE V-TACH"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kiniku Chunks!!! »</TD></TR><TR><TD CLASS="quote">As long as you build it right, you'll be fine. Listen to all advice and make up your own mind. It's you car you can do what you want. </TD></TR></TABLE>
as long as you put posts like this through the idiot filter first, and see how they come out on the other side, youll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">
si/gsr/r oil pumps are the same</TD></TR></TABLE>
the 1.6L ones work? what about the water pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">just wondering, what year is the b16 oil pump? If it is a 95 and below oil pump, then the LS oil pump is actually the superior pump (P72) as the 96+ B motors were equipped with P72 GSR/ITR pumps.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">Motors that have the superior P72 GSR/ITR oil pump:
94+ GSR (B18C)
96+ ITR
96+ B18B
96+ B20B/B20Z
96+ B16A
96+ B16B</TD></TR></TABLE>
Got this from another thread.
94+ GSR (B18C)
96+ ITR
96+ B18B
96+ B20B/B20Z
96+ B16A
so the delsol vtec and 99-00 si b16 oil pump will work.
the main reason i ask isnt nessicarily compatibility, its be cuase of the age old cliche of honda dealers not sellign acura parts. theres a honda dealer close, and the closeest acura one is 2 hrs away in temecula. so, id rather just go pick up a new 22T water pump and 96 delsol oil pump than drive 2 hrs to temecula to get the "type-r which is the KEY!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie »</TD></TR><TR><TD CLASS="quote">i have a type r oil pump</TD></TR></TABLE>
i like pie.
i like pie.
