WTB : COMPLETE b18B/b16a2 LS/SI obd2 swap changeover
as title says.. show me what you got
usdm.. jdm.. dont mater as long as its a healthy running motor with no problems.. complete changoever to my 97ek
I have a built b18b, located in green bay, WI, under 30,000 miles, balanced and blueprinted....
* Head is shaved and P n P(how much I dont know)
* AEM cam gears
* Venom injectors
* CROWER titanium valve springs
* Crower retainers
* Crower cams
* brand new pr4 pistons and rods
* ARP rod bolts
* ARP main studs
* ACL bearings
* b16 oil pump
* K&N performance oil filter
* crank is jacknifed
* brand new valves, seals, GASKETS, etc
* dual centerforce clutch
* brand new spark plugs
* NGK wires
basically its an awesome setup...all parts are new, built from the ground up, It would be perfect for turbo.
1900
* AEM cam gears
* Venom injectors
* Crower retainers
* Crower cams
* ARP rod bolts
* ARP main studs
* ACL bearings
* b16 oil pump
* NGK wires
1900
Mr.Chow
Jan 4, 2007 08:27 PM
Mr.Chow
Dec 15, 2006 09:46 AM
