Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter?
Old Oct 3, 2006 | 09:00 PM
Type X's Avatar
Default Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter?
I've been "brake" shopping....
Come up with a few different kits but pretty much on every forum , I haven't seen ANYONE upgrade yet.
Anyone have any upgrades to the braking system before i shell out 1300 for this Rotora kit?
Thanks
- Mike
Old Oct 3, 2006 | 09:13 PM
06civicracer's Avatar
Default Re: Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter? (Type X)
i've only upgraded the pads,i use the hawk brake pads,works really good for fast breaking and doesnt squeal like most pads,i think brembo came out with a kit,not sure though
Old Oct 3, 2006 | 09:45 PM
jonness's Avatar
All I want is some red brembo brake calipers.
Old Oct 4, 2006 | 05:12 AM
06BlackSi #45's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">I've been "brake" shopping....
Thanks
- Mike</TD></TR></TABLE>
Mike, what kits have you found. I'd love some Brembo's.
Old Oct 4, 2006 | 05:21 AM
Type X's Avatar
Default Re: Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter? (06BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">
Mike, what kits have you found. I'd love some Brembo's. </TD></TR></TABLE>
keep in mind, i'm not going to buy from ANY of the sites listed... this is for informational use only
http://www.streetbeatcustoms.c....html
http://www.vividracing.com/cat...21331
this last one, i'm not sure if there is an application but seems pretty nice
http://www.jhpusa.com/catalog/...78be7
Old Oct 4, 2006 | 06:16 AM
Thanks!
Old Oct 4, 2006 | 07:02 AM
modifyORdie's Avatar
Default Re: Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter? (jonness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonness &raquo;</TD></TR><TR><TD CLASS="quote">All I want is some red brembo brake calipers. </TD></TR></TABLE>
Old Oct 4, 2006 | 07:49 AM
aznchzexr's Avatar
http://www.8thcivic.com/forums...15140
Rotora Slotted and Cross Drilled Rotors
Old Oct 4, 2006 | 08:23 AM
Ding's Avatar
Default Re: (aznchzexr)
Jesus Mike, just bought the last set of the Time Attacks in the country and now another 2-2500 on just front brakes? Baller status. Are there any rear kits out yet?
Old Oct 4, 2006 | 08:55 AM
Declectic's Avatar
wait for Project Mu.... OOOOHHHH sooo seccccsssiiiiiiii!!!
I had the PDF files that showed they were coming out with parts for the FG... think i deleted them though
http://www.project-mu.co.jp/e/e-index.html
Old Oct 4, 2006 | 08:58 AM
Zesti1's Avatar
The last kit looks bad *** especially since it "will" clear 16" rims. That means that us Canuck can still run our 16" winter set up with the system!!!
Old Oct 4, 2006 | 09:46 AM
spoonlongblock's Avatar
TRY FASTBRAKES.COM
Old Oct 4, 2006 | 10:58 AM
capnxtreme's Avatar
I thought it was an established intArw3b fact that the Rotoras are just for looks.
Putting that **** behind those Volks is a crime, IMO.
Old Oct 4, 2006 | 01:35 PM
check these out if you buy one of them let me know if they will clear stock rims
http://fastbrakes.com/shop/index.php?cPath=28_165
Old Oct 4, 2006 | 02:34 PM
Caveman74's Avatar
Default Re: Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter? (spoonlongblo
I was looking at the Power Slot Rotors.. I'm not sure on crossdrilled, seen too many cracked.
Old Oct 4, 2006 | 09:44 PM
autoone's Avatar
Brembo still the best
Old Oct 5, 2006 | 11:44 AM
Hellzcivic's Avatar
I knew I would find this if I looked hard enough. Brembo has a front kit. Not sure of the price since it is not lists
http://www.brembo.com/Catalogo...Guest
Select Honda and SI Coupe Front (like you needed to know that).
Old Oct 5, 2006 | 01:41 PM
sickyute's Avatar
Default Re: Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter? (Hellzcivic)
i did some mild upgrades....
Hawk HPS pads f+r
edelbrock/russell stainless steel brake lines f+r
stop tech slotted rotors (oem size though)
motul rbf 600 brake fluid..
so far it feels real nice...i know for sure i've decreased stopping distance...
i don't think the rotors do much....but they sure look damn good...
http://www.cardomain.com/ride/2216565/2 FOR PICS.
i will in time change to bigger rotors...like poweslot big brake rotor when it's available...but everything else stays the same.
Old Oct 5, 2006 | 02:01 PM
Default Re: Anyone Running a Big Brake kit for the Fg2? or ANY brake upgrades for that matter? (sickyute)
you should upgrade to a wilwood brake kit as it would give you bigger calipers and more pistons per caliper but also bigger rotors
Old Oct 5, 2006 | 02:29 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonlongblock &raquo;</TD></TR><TR><TD CLASS="quote">you should upgrade to a wilwood brake kit as it would give you bigger calipers and more pistons per caliper but also bigger rotors</TD></TR></TABLE>
this type of upgrade is unecessary for a daily driver car....
for daily driving all you need to do is upgrade brake pads, brake lines, brake fluid, and maybe some brembo blanks...
other than that, the rest is just throwing the money around making ur **** look pretty
Old Oct 5, 2006 | 02:32 PM
I was talking to sickyute who has enough power in his car to put a bigger caliper and rotor on and make use of it
Old Oct 5, 2006 | 02:38 PM
sickyute's Avatar
i might just do that...
just waiting for more options where that is concerned...
Old Oct 6, 2006 | 10:27 AM
tRex99's Avatar
I talked to fast brakes about a sponsorship and they told me to send my stuff in because they do have a few different sets for the new either in production or finished product. just email them up and say Dwight with the 2006 S/C civic Si sent me
Old Nov 5, 2006 | 05:13 PM
gonna bring this abck from the dead....
fastbrakes just came out with a kit that is $1600 but includes 12.2 rotors and brackets and Brembo Calipers with Hawk Pads. I just emailed them to see if they will work on stock wheels as they say you need 17" wheels but they come stock on cars. The brembos are off the new TL Type S I believe.
http://www.fastbrakes.com
Old Nov 5, 2006 | 06:50 PM
Type X's Avatar
there is an HFP brake upgrade due for release in the spring.
I'll have a post up tomororw night with all my SEMA findings....
