need help on heater problem on my 95?
Old Oct 3, 2006 | 08:44 PM
speshuled619's Avatar
Default need help on heater problem on my 95?
my girlfriend has a 95 accord and she is having heater problems. the a/c works and blows out just fine as well as the windshield defroster. we are having problems with the heater. it wont blow the hot air out. what can be the problem? the heater core has been replaced so its new. please help me out. winter is coming up. thanks guys.
ed
Old Oct 3, 2006 | 09:20 PM
drktorn's Avatar
Default Re: need help on heater problem on my 95? (speshuled619)
you might want to check the climate control wire when you twist the **** does it open can close the valve?
Old Oct 9, 2006 | 09:02 AM
Default Re: need help on heater problem on my 95? (drktorn)
ill try looking at that. are there any other possible things that i should look at?
Old Oct 10, 2006 | 02:07 PM
JimBlake's Avatar
What's the real problem? Does it not blow air to your feet? Or does it blow air & never gets HOT?
If it never gets hot, check the cable from the temperature control. It works an air damper in addition to the water valve.
xKAMILxEK
Dec 3, 2009 08:42 PM
blkcivic310
Aug 5, 2009 10:44 AM
jdmtim661
Jul 19, 2009 07:11 PM
Chgoaccordguy
Jan 10, 2008 05:55 PM
MTB
Oct 15, 2007 12:33 PM
