motor and turbo kit
Old Oct 3, 2006 | 07:00 PM
civicliveit's Avatar
Default motor and turbo kit
ok, time to clean the 2 biggest items out of the garage.
I have a disassembled 2000 B16a2 out of a civic si for sale. Motor needs to be honed, cleaned up and put back together. The only part you will have to buy for this motor is a set of pistons and rings. I have everything else to put it back together. Parts list is as follows:
AEBS head studs
Clevite 77 Bearings
Eagle H Beam Rods
Honda gaskets /seals
New valve seals for the head
Block
Head
Alternator
Brackets
Intake manifold
Throttle Body
All sensors
OBD 1 DOHC VTEC Distributor
Oil Pan has a turbo drain in it but that can be plugged
If you have a swap now but are thinking of building your motor, this is the way to go. Buy this one, build it and take a weekend to swap your motor out for this built engine. $1100 obo
Drag Gen 3 Turbo kit minus turbo and downpipe. YOu can find a t3/t4 50 trim on ebay for roughly 250-300 bucks. Get a downpipe flange for 30 bucks and have someone make you a dp for next to nothing and have a great turbo kit to go with the B16 for cheap. $700
PM if you want pics
_________________
Moving on in life just seems to get better and better............
Na-Spirit
Nov 10, 2007 12:07 PM
818wHtEG6
Dec 11, 2006 08:16 AM
civicliveit
Oct 9, 2006 07:08 PM
