motor and turbo kit
Old Oct 3, 2006 | 07:00 PM
civicliveit's Avatar
Default motor and turbo kit
ok, time to clean the 2 biggest items out of the garage.
I have a disassembled 2000 B16a2 out of a civic si for sale. Motor needs to be honed, cleaned up and put back together. The only part you will have to buy for this motor is a set of pistons and rings. I have everything else to put it back together. Parts list is as follows:
AEBS head studs
Clevite 77 Bearings
Eagle H Beam Rods
Honda gaskets /seals
New valve seals for the head
Block
Head
Alternator
Brackets
Intake manifold
Throttle Body
All sensors
OBD 1 DOHC VTEC Distributor
Oil Pan has a turbo drain in it but that can be plugged
If you have a swap now but are thinking of building your motor, this is the way to go. Buy this one, build it and take a weekend to swap your motor out for this built engine. $1100 obo
Drag Gen 3 Turbo kit minus turbo and downpipe. YOu can find a t3/t4 50 trim on ebay for roughly 250-300 bucks. Get a downpipe flange for 30 bucks and have someone make you a dp for next to nothing and have a great turbo kit to go with the B16 for cheap. $700
PM if you want pics
_________________
Moving on in life just seems to get better and better............
Old Oct 4, 2006 | 08:12 AM
CBR_15's Avatar
no wire harness, axles, tranny or ecu?
Old Oct 6, 2006 | 10:19 PM
RICHBCM's Avatar
Default Re: (CBR_15)
how many miles on the kit
Old Oct 9, 2006 | 07:08 PM
CBR_15 - I have a set of axles, and a p30 ecu. No wire harness or trans. Axles and half shaft would be an extra $200 and the ECU would be $175. Bought the ECU new from honda about 4 years ago. Never opened up.
RICHBCM - turbo kit has about 50k on it. No turbo or downpipe included with this. Intercooler has never been on the car, mocked it up but never ran it.
Na-Spirit
Nov 10, 2007 12:07 PM
818wHtEG6
Dec 11, 2006 08:16 AM
