Weird click noise 5 seconds after the R started...
Old Oct 3, 2006 | 06:25 PM
T3k C's Avatar
Default Weird click noise 5 seconds after the R started...
So I just found this tonight while doing a comp check. Few seconds after I start my R, I hear a sucking noise and then a CLICK and then it stops ( quieter ) but the car still running. It really sounds like the click comes from the starter. Here's a short video, it sounds like the fan is going off but it isn't even on.
http://s82.photobucket.com/alb...1.flv
Old Oct 3, 2006 | 06:30 PM
RTW DC2R's Avatar
Default Re: Weird click noise 5 seconds after the R started... (T3k C)
does it do this on both hot and cold starts?
Old Oct 3, 2006 | 06:32 PM
T3k C's Avatar
I would have to try on cold start, it was hot when I recorded it.
Old Oct 3, 2006 | 07:33 PM
Chris F's Avatar
Sounds like your starter didn't disengage! Maybe a sticky solenoid thing. Sounds exactly like that. You should hear it from the starter on top of the tranny, not popping off the flywheel right.
Old Oct 4, 2006 | 10:11 AM
mugenracer's Avatar
Are you sure its not just teh ABS pump priming after start up, sort of makes a buzzing type noise for a few seconds then stops, it may be more apparent with the hood up...?
Old Oct 4, 2006 | 11:46 AM
T3k C's Avatar
Default Re: (mugenracer)
^^ That could be it. But I hear a click noise also, would that be from that? This morning when i started my car with engine cold, I didn't hear anything. Will try again with engine warmed up and see what's going on. Maybe switch out starter since I have one laying around.
Old Oct 4, 2006 | 11:48 AM
walker111's Avatar
Default Re: Weird click noise 5 seconds after the R started... (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your starter didn't disengage! Maybe a sticky solenoid thing. Sounds exactly like that. You should hear it from the starter on top of the tranny, not popping off the flywheel right.</TD></TR></TABLE>
Thats what I thought at first, I've never heard of that happening though!
92tegzz
Jan 26, 2007 07:10 PM
RTW DC2R
Apr 28, 2006 12:44 PM
ptype
Honda S2000
Dec 6, 2005 01:53 PM
jdmgeorge
Mar 9, 2004 06:45 PM
Gedupsound
Oct 4, 2003 01:56 PM
