Main relay ?
Old Oct 3, 2006 | 05:40 PM
Waynebo's Avatar
Default Main relay ?
Anybody know where the main relay is located on a 91 Accord? Intermittent starting during warm to hot days in the parking lot at work. I have to get that problem fixed but I cant find the stupid thing. I would appreciate a fine description of the location please.
Old Oct 3, 2006 | 05:46 PM
Honda_Accord's Avatar
Default Re: Main relay ? (Waynebo)
if u go to the accord faq's and scroll down u till u see Specifications
Electrical you will find alot of main relay info there
Old Oct 3, 2006 | 05:59 PM
hondadude's Avatar
Search is your friend on this question....
You'll have to go dash diving to find this jewel. grab up a 10mm deep socket and a medium exrtension on your handy dandy ratchet. Lay on your back in the drivers floor board with your head where you usually have your stinky feet.
The cruise control unit needs to be removed,[LX EX] it's mounted hanging at about a 45 degree angle, to the left of the steering column, get it unbolted, swing it out of the way. the main relay is mounted above that with one 10mm nut and the other hole of the bracket has a stud sticking thru it. You can only see the bottom of the relay, where the electrical connector is[8 wire I think] grey box, on the side of it it will read 'MITSUBA RZ 0088' You have the option of leaving the case bolted in and popping the guts out of the case with a small screwdriver.
When you have the guts out you want to look for bad solder joints at either end of the relay board. resolder them and pop it back in the car.
this link might help you some more.
http://www.hondaaccordforum.co...m.htm
deadhead23
Jan 15, 2021 10:43 AM
closs2sx
Oct 28, 2008 05:48 PM
romeoz24_2000
Aug 12, 2008 04:03 AM
MechEng
Dec 27, 2002 12:09 PM
