new 2000 cluster w/electronic vss....now a cel......yes i've searched
Old Oct 3, 2006 | 05:19 PM
crxmex's Avatar
Default new 2000 cluster w/electronic vss....now a cel......yes i've searched
ok i've installed the cluster everything worked fine but the speedo "i know it has to have the e-vss" so i picked one up from a friend wired it in and hooked up to pin b16 now i get a cel. the code "obd 0 pr3 ecu if it helps " goes as follows:
bllllllllllliiiiiiiiiiinnnnnnnnnnkkkkkkkk
bllllllllllliiiiiiiiiiinnnnnnnnnnkkkkkkkk, blink
wtf is goin on?
Old Oct 3, 2006 | 05:34 PM
crxmex's Avatar
Default Re: new 2000 cluster w/electronic vss....now a cel......yes i've searched (crxmex)
come on guys need info
car has to be running by morning only vehicle i have
Old Oct 4, 2006 | 01:43 PM
crxmex's Avatar
ok so no one knows? or what....i've tried switching the power to the signal wire and the signal to the ground and splitting the **** and nothing i have no vtec and the code is a 21 which i didnt even know the pr3 ecu had...any help would be GREATLY APPRECIATED!!!!
Blaze45
16
Jan 20, 2012 08:11 AM
chad
Apr 13, 2009 06:43 PM
civichatch2307
Aug 7, 2007 07:06 PM
schwanginpt
Jun 28, 2004 08:05 PM
PotatoePAPA
May 19, 2004 05:32 PM
