91 civic 4dr ex sputters
i recently got a 91 civic 4dr ex. when i take off the car hesitates and it sputters a little bit as if the fuel wasn't getting thru the injectors. it also does it when im driving it at low rpm. i put fuel injection system cleaner in the gas tank twice in the last 2 months but it hasn't helped. the throw out bearing is also bad cause i acn hear it. im replacing the clutch this weekend. can anyone help or give any suggestions of what it could be or what to do?????
check the tps, jiggle the wire and see if it sputters at idle or if the idle changes, could aslo be dizzy related, maybe a weak coil or corrosion on the contacts of the cap
when i got the car i gave it a tune up, new plugs,wires, cap,rotor and oil change. today i did notice that there was a little bit of oil on the block near the distributor. im going to check on that tommorrow. anyone else got ideas???
91hondaaccord
Oct 24, 2011 06:19 PM
DailyDriverCivic
Jan 7, 2008 12:08 AM
