Poorman's type R hp rating track times
Old Oct 3, 2006 | 05:03 PM
bustdgst's Avatar
Default Poorman's type R hp rating track times
alright guys, just put in a gsr block w/b16 head in my ek civic. ITR cams, and the usual intake header exhaust combo. Does anyone that has had experience with this set up know what kind of power I should expect from this set up...im currently running a si ECU but about to change over to a chipped p28. how about track times? thanks!!!
Old Oct 3, 2006 | 05:31 PM
vxhatched's Avatar
Pretty heavy car to go fast with just bolt ons. Maybe A decent tune on a Hondata you could be in the Low 15's or High 14's with traction (slicks)
Old Oct 3, 2006 | 06:21 PM
bustdgst's Avatar
Default Re: (vxhatched)
how much power do u think this set up should put out? are these civics really that heavy?? weight??
Old Oct 19, 2006 | 11:24 PM
ek_b16's Avatar
Default Re: (bustdgst)
dont lose hope man.. I'm on the same setup.. best time is 13.8 at 102mph.. I'm not sure about the hp but i know it anit much.. just takes a good driver.. This was with full interior and street tires.. depends on driver and skills..
Old Oct 20, 2006 | 07:13 PM
TealEG!'s Avatar
i would say mid to high 14's once you get the right ecu or a good tune.
Old Oct 23, 2006 | 12:38 AM
allmotorcrx415's Avatar
Default Re: Poorman's type R hp rating track times (bustdgst)
get a Hondata s200 i have the same set up wid a Blox hsl cams (high speed lift) i ran 13.4 wid a shitty street tires...
Old Oct 23, 2006 | 04:46 AM
Honda Bull's Avatar
Default Re: Poorman's type R hp rating track times (allmotorcrx415)
I'd estimate somewhere in the 165- 175 whp range for power (once tuned). 14 second timeslips atleast with a good track, conditions, and driver.
mesmurize
Jun 10, 2015 03:48 AM
vtak2nr
Sep 21, 2011 05:18 AM
Schister66
Jan 17, 2006 06:33 PM
JBk24crx
Jun 16, 2004 12:53 PM
chuckd05
Mar 23, 2003 06:10 PM
