poorman type r
only if u do it right i see to many people slapping on heads and saying its a poor man type r u have to replace the head gasket and pistions in order for it to be a true poor mans. otherwise its just ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-gorilla »</TD></TR><TR><TD CLASS="quote">is a poorman type r worth it or not? or should i just go straight gsr?
From scratch, not worth it. If you already have everything from a B16 (head/tranny/pistons mostly), then yeah.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmbreed »</TD></TR><TR><TD CLASS="quote">only if u do it right i see to many people slapping on heads and saying its a poor man type r u have to replace the head gasket and pistions in order for it to be a true poor mans. otherwise its just ****</TD></TR></TABLE>
Changing the headgasket is essential but has nothing to do with making it a "true poorman's R"
More about swapping out the GSR pistons with at least ITR at the minimum and ITR cams at the minimum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
More about swapping out the GSR pistons with at least ITR at the minimum and ITR cams at the minimum.</TD></TR></TABLE>
Exactly what he said, check out the link in my signiture for an example of a poormans ITR.
