crx hatched back glass question?/????
ok is there a way to get it off. like easy, razor blade, chemical, ect. i try to put a sign in the back that i've made at my work.
http://myweb.cableone.net/oaks....html
if any one has seen the show trick my truck on CMT, then u've seen the signs we make.
thanks
thanks
Inside or outside?
Inside you are going to be bummed because of the rear defroster, and I have no suggestions.
Outside use a razorblade and some "Goo Gone" or that orange stuff to loosen the stickey stuff.
inside in the very back the glass window with the hatched pattern in it . i need to get it off so it will show the sign.
siXUNE
Jul 2, 2013 07:29 AM
