DOHC ZC want to remain stock exhaust on DX, which header?
Old Oct 3, 2006 | 11:50 AM
thenick's Avatar
Default DOHC ZC want to remain stock exhaust on DX, which header?
Hey guys, I'm swapping in a DOHC ZC and I was curious if I wanted to retain the stock DX exhaust which header and flex pipe do I use? Can I use my stock DX header and flex pipe? Thanks
Old Oct 3, 2006 | 12:11 PM
Outsane's Avatar
Default Re: DOHC ZC want to remain stock exhaust on DX, which header? (thenick)
yeah
Old Oct 3, 2006 | 12:12 PM
1990crxAKAlexi's Avatar
should be able to use your stock manifold...just have to port match...the zc exhaust ports dont line up with reg d series manifolds and headers...could be wrong though....
Old Oct 3, 2006 | 05:37 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: DOHC ZC want to remain stock exhaust on DX, which header? (1990crxAKAlexi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990crxAKAlexi &raquo;</TD></TR><TR><TD CLASS="quote">should be able to use your stock manifold...just have to port match...the zc exhaust ports dont line up with reg d series manifolds and headers...could be wrong though....</TD></TR></TABLE>
You're right, you will have to port-match the exhaust mani. You MAY have to use the EG bolts to hold your downpipe to your cat. converter because they're longer. I got these when I used a D16A6 header on my DOHC, the stock bolts were just a little short.
sean burke
Apr 20, 2009 05:34 PM
BlueRex1020
13
Oct 26, 2006 07:24 PM
mateencrx91
23
Jan 23, 2004 12:10 PM
tdc
Feb 25, 2002 04:30 PM
tdc
Feb 3, 2002 06:32 PM
