Drove over a bump and everything but headlights died
Old Oct 3, 2006 | 10:33 AM
Luka's Avatar
Default Drove over a bump and everything but headlights died
Coming home from my gf's house last night i was just getting off the hwy a few minutes later down the road i hit a bump in the road, didnt feel like that big of a a bump but it made my deck skipp. Right at that point the radio powered off dash lights whent out and complete loss of power. My headlights were still working so i quickly pull over to the side and check over my fuses, they all checked out.
So keys in turned to ignition on ii,
- dash lights dont come on
- interior lights are bright and so are the headlights
I have been experianceing dash lights dimming for the past little few months on and off, mostly when it gets humid and cold out.
ideas or common breakdowns on this?
any and all advice is well appreciated, Thanks
Old Oct 3, 2006 | 10:45 AM
Luka's Avatar
Default Re: Drove over a bump and everything but headlights died (Luka)
ive been on the search for the past hour and a bit, and most ive come up with would be bad grounds??
Old Oct 3, 2006 | 10:47 AM
CRXBart's Avatar
Did any tripod looking alien crafts rise from the ground at the same time by chance? If so you've got more to worry about.
Old Oct 3, 2006 | 01:19 PM
Luka's Avatar
Default Re: Drove over a bump and everything but headlights died (CRXBart)
lol ahhh h-t how ive missed you...
Old Oct 3, 2006 | 01:44 PM
didyouhearthat's Avatar
Battery cables/terminals loose or corroded? Alt. wire loose or disconnected?
Are you able to restart the car?
Old Oct 3, 2006 | 01:48 PM
Luka's Avatar
Default Re: Drove over a bump and everything but headlights died (didyouhearthat)
the car wont go into ignition position like none of the dash lights will come one the anoying beep doesnt happen im goin out there to clean up the grounds make sure their all good and double check the fuses, it was dark and i didnt have a light last night.
thanks. Lucas
Old Oct 3, 2006 | 02:03 PM
thesmogman's Avatar
Is your intake by your battery? Did you short out the intake on the + of the battery?
Check your fuses both inside and out in under the hood.
Old Oct 4, 2006 | 02:18 AM
Luka's Avatar
Hey guys thanks for the help, i always freak out when things happen unexpectantly with the car, due to my still growing knowledge on cars hehe.
Found the culprit, was the 50amp ecu fuse under the hood, replaced it for $2 ecu's not throwing any codes, so im still unclear as to what caused it to blow but so far so good
Thanks again
Lucas
Old Oct 4, 2006 | 02:31 AM
JeDiMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">Did any tripod looking alien crafts rise from the ground at the same time by chance? If so you've got more to worry about. </TD></TR></TABLE>
hahahahahaha
But yeah thats wierd
I guess Barts theory could quite possibly be reality .... 'insert twilight zone music here' ....
Old Oct 4, 2006 | 07:06 AM
Tippyman's Avatar
Maybe the military is testing EMP devices in your area.
BUMP 4 a weird problem...
cjwang2
Sep 3, 2016 08:16 PM
beefisforbadbwo
Honda Civic (2001 - 2005)
Dec 27, 2013 03:08 PM
blacc_ej1
Lighting
Oct 13, 2010 02:58 PM
BLU BY U
Sep 26, 2006 07:39 PM
