brake clearance/rub
i have an 89 crx si w/ 93 integra gsr brake calipers.
both calipers are relatively new....less than a year old.
i recently installed BREMBO cross drilled rotors on both front calipers and im using gran sport carbon/ceramic pads as well.
it seems to be that since both the rotors and pads r both very thick, the clearance is not much, so in town driving (stop and go) seems to cause the brakes to drag/grab a little because my air gap is not enough.
does any1 know which brake pads i can use with 93 gsr calipers that are thinner or will fit better?
