my aem chewed through my AC lines!
Old May 2, 2002 | 05:11 AM
uNF$@#!'s Avatar
Default my aem chewed through my AC lines!
help! my aem chewed through my ac lines! and as a result my A/c never works as cold as it used to!
is there something i can buy to "reapply" the insulation? TIA
Old May 2, 2002 | 05:18 AM
Dropspeed's Avatar
Default Re: my aem chewed through my AC lines! (00-0187)
If there is a hole in your a/c line it will either work or it won't, Freon is a gas and will leak very quickly if there is a hole. If it just wore through the insallation, your fine its only in your head. If there is an actual hole in the line just replace it with a new one
Mattj
Old May 2, 2002 | 05:21 AM
uNF$@#!'s Avatar
Default Re: my aem chewed through my AC lines! (Dropspeed)
it just wore through the insulation... im sure that insulation really helps with the A/C as the A/C doesnt work well anymore.... (compared to a honda civic A/C)
thanks for the reply...but do you know of anything to replace that insulation?
[Modified by 00-0187, 9:21 AM 5/2/2002]
[Modified by 00-0187, 9:22 AM 5/2/2002]
Old May 2, 2002 | 05:34 AM
sackdz's Avatar
Thanks for the reply...but do you know of anything to replace that insulation?
The insulation material you wore thru will have no effect whatsoever on the cooling performance. Grab some duct tape wrap it up and call it a day. Also you may want to move your lines out of the way so they won't touch the AEM. Try zipties.
Old May 2, 2002 | 06:49 AM
nerdish's Avatar
Default Re: my aem chewed through my AC lines! (sackdz)
Zipties own.
I was careful to make sure my AEM didn't rub the AC lines.. I should check to make sure it still isn't. I never use AC anyways though..
Old May 2, 2002 | 07:55 AM
01-1293's Avatar
Default Re: my aem chewed through my AC lines! (nerdish)
JohnnyBoy installed my AEM and he did a great job to address this problem.......ziptied my A/C lines together to bring the outer line farther away from the intake........then he put a foam piece in between the lines and the intake.......works great.........zero rubbing.............couldn't be any happier
Old May 2, 2002 | 09:21 AM
98TypeR's Avatar
Default Re: my aem chewed through my AC lines! (01-1293)
i think that your ac might need to be recharged. Dont' the R's have a smaller less consuming ac unit than other cars?
Old May 2, 2002 | 09:48 AM
PM-Performance's Avatar
i zipped tied my lines together, , , then my nitours nozzle rubbed the line and put a hole in it . . . say buh bye to ac. its all gone and alot lighter and more power.
ac is overrated anyway
Old May 2, 2002 | 10:55 AM
STOLEN - ITR 98-0652's Avatar
I guess turnabout is fair play... my A/C lines chewed (half-way) through my AEM.
Old May 2, 2002 | 11:02 AM
InfamousRS's Avatar
Default Re: my aem chewed through my AC lines! (ITR 98-0652)
Me too! Im kinda pissed about it.
Old May 2, 2002 | 11:04 AM
98ITR#0020's Avatar
My AEM got worn by the AC line so I cut up an old bike tire,wrapped it twice and zip tied it on both sides. No problems for almost a year now.
Old May 2, 2002 | 11:21 AM
Default Re: my aem chewed through my AC lines! (BLK94RS)
Well, when/if the AEM is destroyed by the A/C lines (currently bound with zipties)... it'll just force me to go with the Mugen CAI. Then, I'll show those A/C lines "who's da boss". (smack! Tony Danza!)
Old May 2, 2002 | 11:52 AM
well the 1st week i had mine those nuts on the lines right where the coolant res is , , , they put a nice gauge in my aem too. thats when i ziptied them
my aem is all jacked up , i need a new one .
Old May 2, 2002 | 11:56 AM
Larkin W.'s Avatar
Default Re: my aem chewed through my AC lines! (itr206)
Solution to your problem : Remove the A.C. = Weight reduction
jk.
Larkin who only uses his A.C. to defog in the winter time
Old May 2, 2002 | 12:13 PM
Default Re: my aem chewed through my AC lines! (EbboyPSi)
that was my solution in the long run .
Old May 2, 2002 | 12:44 PM
B2FiNiTY's Avatar
Mine was rubbing and I adjusted it a bit and there is plenty of clearance now.
mattL
May 19, 2003 10:53 AM
mattL
May 19, 2003 10:07 AM
01-1293
Sep 5, 2002 03:03 AM
94autotegLS
Mar 8, 2002 08:25 PM
friedsqrl
Jan 25, 2002 12:40 PM
