Carsound Cat short???
Old May 2, 2002 | 04:20 AM
ITR0145's Avatar
New User
Default Carsound Cat short???
Tried installing a carsound cat with my JDM 4-1 header and it's coming up short 2 - 3" or so from the rear exhaust connector. What part # is the one you guys have on your ITR's??
Old May 2, 2002 | 04:24 AM
Dropspeed's Avatar
Default Re: Carsound Cat short??? (ITR0145)
Ther is no factory "direct" bolt in replacement, you need to have the flanges welded on to make it work.
Mattj
Old May 2, 2002 | 04:25 AM
Cosworth's Avatar
Did you get the "bolt-on" kind? Where did you get it at? It should fit without a problem...
[edit] it should fit w/o a problem if you got a "bolt-on" carsound cat. [/edit]
[Modified by Cosworth, 8:26 AM 5/2/2002]
Old May 2, 2002 | 04:39 AM
Back in Black's Avatar
Rather OG
If you did get the carsound bolt-on application, which model did you buy? (ie: 54006/94006)
Depending on whether you're running a JDM length exhaust, that's probably your problem right there. The 54006 is the shorter cat, while the 94006 is longer.
HTH
Old May 2, 2002 | 06:00 AM
ITR0145's Avatar
New User
Default Re: Carsound Cat short??? (Vader in NC)
It's 94006.....it's the bolt on kind
Old May 2, 2002 | 06:01 AM
ITR0145's Avatar
New User
Also trying to run the stock exhaust
Old May 2, 2002 | 06:16 AM
SMSP's Avatar
Are you sure it's the 94006 and not the 94066? It would be difficult to build either of these cats to be 2-3" short with the stock B pipe.
Old May 2, 2002 | 06:20 AM
R-Rated's Avatar
I have the 54006 and it fits fine. I thought the 94006 is a little to long and must be adjusted.
Old May 2, 2002 | 07:53 AM
Padawan's Avatar
Darth ModerVader
Where did it come from? Dave's cat. fit flawlessly on my car, and I've never heard any complaints about Mike's either.
Old May 2, 2002 | 07:56 AM
Cosworth's Avatar
It'll sound funny, but is that the OEM JDM 4-1 header?
Old May 2, 2002 | 08:01 AM
Mike B's Avatar
Cant you just pull on the B-pipe till it fits?
Old May 2, 2002 | 08:19 AM
azn98R's Avatar
Default Re: Carsound Cat short??? (R-Rated)
I have to check mine when I get home, but I was told the 97 & 98 ITR's are in different lengths than the 00 & 01 ITR's
Old May 2, 2002 | 08:24 AM
azn98R's Avatar
Default Re: Carsound Cat short??? (Crazy Bovine)
2-3" is a huge differance. to pull the catback back towards the cat, there's a big chance your exhaust will no longer fit your car. Where did you get it from call them back...pritty sure they will get you the right one.
Old May 2, 2002 | 09:17 AM
ITR0145's Avatar
New User
Default Re: Carsound Cat short??? (azn98R)
I'm thinkin I might be able to get some longer bolts and springs to try and stretch it to the collector. If that doesn't work....hmmm??
Old May 2, 2002 | 09:23 AM
UNVMYR's Avatar
please post your out come...as I have the same set up and cant get rid of the buzzy shound i get while the car is still cold???just have them weld an extention!!(my carsound has been tack welded as well)
Old May 2, 2002 | 09:29 AM
ITR0145's Avatar
New User
Default Re: Carsound Cat short??? (UNVMYR)
Anyone have pics of their cat??
Old May 2, 2002 | 09:35 AM
Mike M's Avatar
Founding Member
Where did you get the cat? And what model # is on the box?
Old May 2, 2002 | 10:13 AM
ITR0145's Avatar
New User
Default Re: Carsound Cat short??? (TypeRmsm)
It says 94006 on the box. Dave is workin on the problem as we speak
Old May 2, 2002 | 10:23 AM
sgT's Avatar
sgT
All ITR and RS/LS/GS header/cat/exhaust systems are the same.
The GSR was different in 1994-99, then changed to the same as above
for either 00 or 01.
Skeletor
Mar 16, 2005 03:12 PM
1998teg
Jul 29, 2004 11:29 AM
Hukd Up
Apr 2, 2003 05:51 PM
Flux
Nov 13, 2002 12:49 PM
ShiftDown
Aug 6, 2002 02:36 PM
