need help...where can i buy this..?????
Old Oct 2, 2006 | 11:38 PM
cd5_2NR's Avatar
Default need help...where can i buy this..?????
okay...one of my luminics yellows finally went out...and looks like the prongs might have melted the plastic around it causing it to get stuck...anyone know where i can buy the socket that the bulb goes into...
the white thing...
i know you guys are probably wondering why i needs that connector...after buying aftermarket headlights...it came with a stupid wire conversion that changed mines to h1's....instead of 9006 or 007....
Old Oct 2, 2006 | 11:48 PM
TranspeedMotorsports's Avatar
Your best bet (cheapest and most convienent), is to buy new bulbs.
Old Oct 2, 2006 | 11:51 PM
cd5_2NR's Avatar
Default Re: (Transpeed Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transpeed Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet (cheapest and most convienent), is to buy new bulbs.</TD></TR></TABLE>
i do have replacement bulbs already..but i wont be able to hook them up...i need that white piece...
in the pics...that white socket...hooks up to that wire that converts my lights to h1's....then you put h1 bulbs into that white socket...get it..??
wonder if i can buy that socket at any local automotive shop...
Old Oct 3, 2006 | 12:17 AM
lthao61's Avatar
Default Re: need help...where can i buy this..????? (cd5_2NR)
good q'
Old Oct 3, 2006 | 02:22 AM
SPITVENOM67's Avatar
Default Re: (cd5_2NR)
Old Oct 3, 2006 | 02:27 AM
Old Oct 3, 2006 | 04:41 AM
Sa.L.aS's Avatar
Carpe diem!
Default Re: need help...where can i buy this..????? (SPITVENOM67)
Old Oct 3, 2006 | 04:43 AM
fventura03's Avatar
try yanking with some pliers or something. you'd probably have to go to the place you bought these from for that piece, but why not go to the original bulb size?
Old Oct 3, 2006 | 07:23 AM
cd5_2NR's Avatar
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">try yanking with some pliers or something. you'd probably have to go to the place you bought these from for that piece, but why not go to the original bulb size?</TD></TR></TABLE>
cant...because the headlight assembly is also made for h1...
Old Oct 3, 2006 | 08:08 AM
cd5_2NR's Avatar
grr..i eventually got the old bulb out...and now the socket is all beat up...
put the new bulb in..works fine...i'll eventually need to replace the socket one day...
Old Oct 3, 2006 | 08:10 AM
_carboy's Avatar
looks like the same socket from the prelude headlights
honda part # 33116-SD4-961
every honda dealer should have them in stock
Old Oct 3, 2006 | 08:24 AM
cd5_2NR's Avatar
Default Re: (_carboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _carboy &raquo;</TD></TR><TR><TD CLASS="quote">looks like the same socket from the prelude headlights
every honda dealer should have them in stock </TD></TR></TABLE>
thanks...i was able to fix it..but now the socket is all jacked up...but still works...i'll eventually have to replace it sooner or later...
distortedfuture
45
Feb 6, 2004 12:48 PM
GQ Cowboy
11
Dec 2, 2003 11:29 PM
tegrunner
Nov 22, 2003 03:04 PM
accordblk
Feb 6, 2003 10:42 AM
