Anyone have good info on proportioning valve and brake booster swap?
i've looked all over and couldnt find any good information. could someone explain how to swap the proportioning valve. i have a 92 vx and want to swap with an integra one but the lines dont match up. anyone got any good pics and info on the install. same with the brake booster and master cylinder.
theres tons of threads on this in the archive but i know that gets confusing sometimes.
go 1" by getting a '98+ abs integra (gsr,ls or itr its all the same folks) booster and m/c. i used a '99 ls m/c with abs and booster didnt have to reflare one of the lines and both were 10mm.
then get a 94+ integra gsr 40/40 prop. valve (yea some say you can keep your oem, i went bigger, and yes early '91 integras used the same one aswell)
but this is all doesnt make sense if you dont also upgrade you front rotors and calipers to '94 gsr and aswell your rears too.
