started a parts list for my new motor i am building this winter
Old Oct 2, 2006 | 09:28 PM
JDM_EK_621's Avatar
Default started a parts list for my new motor i am building this winter
hey whats going on guys i have started a parts list for my winter build
hit me up with some thoughts or ideas on what else i should buy
this is going in to a B16A
Portflow B-Series VTEC Titanium Retainers Portflow B-Series VTEC Titanium Retainers
$140.00USD
Portflow B-Series VTEC Inner Valve Springs Portflow B-Series VTEC Inner Valve Springs
$80.00USD
Supertech B-Series VTEC High Compression Race Valves Supertech B-Series VTEC High Compression Race Valves
$240.00USD
JDM Integra-R P73 Piston Set (OS) JDM Integra-R P73 Piston Set (OS)
$199.00USD
ACT B-Series Hydro Tranny Heavy Duty Clutch Kit w/ 6 Puck Sprung ACT B-Series Hydro Tranny Heavy Duty Clutch Kit w/ 6 Puck Sprung
$390.00USD
ACT B-Series Streetlite Flywheel ACT B-Series Streetlite Flywheel
$209.00USD
ARP Head Studs B16A ARP Head Studs B16A
$137.00USD
Mugen B-Series VTEC Head Gasket Mugen B-Series VTEC Head Gasket
$140.00USD
RC High Performance Saturated Fuel Injectors 310cc RC High Performance Saturated Fuel Injectors 310cc
$280.00USD
Walbro 255LPH Fuel Pump Walbro 255LPH Fuel Pump
$109.00USD
Walbro Fuel Filter Kit (in-tank) Walbro Fuel Filter Kit (in-tank)
$12.00USD
Sub-Total: $1,936.00USD
Old Oct 3, 2006 | 04:14 AM
RStoR's Avatar
Default Re: started a parts list for my new motor i am building this winter (JDM_EK_621)
OEM parts you should replace while the block is out...
Upper Gasket Kit
Lower Gasket Kit
Oil Pump
Timing Belt
Timing Belt Tensioner & Spring
Water Pump
Piston Ring Set x 4
Water Passage Pipe O-Rings x 2
Oil Control Orifice on Block
O-Ring for Breather Box (if applicable)
O-Ring on Head (Sits underneath the center Camshaft Holder)
Dowel Pins for Head (just incase it is damaged or lost during disassembly - happens quite often)
Throttle Body Gasket (Not included with Upper Gasket Kit)
Fuel Injector O-rings (If needed)
Honda-Bond
VTEC Solenoid Gasket and O-Ring
O-Rings for Intake and Exhaust Rocker Shaft Orifice
Washers for Block Freeze Plugs
Thermostat & Gasket
You should also replace/upgrade the rod bolts.
Do you have fuel management for the bigger injectors?
Do you plan to upgrade the cams? If so....upgrade outer valve springs and LMA.
Old Oct 3, 2006 | 07:18 AM
Rukusmasta2's Avatar
Default Re: started a parts list for my new motor i am building this winter (RStoR)
New Rod and Main bearings along with the thrust washers
Old Oct 3, 2006 | 03:16 PM
JDM_EK_621's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">OEM parts you should replace while the block is out...
Upper Gasket Kit
Lower Gasket Kit
Oil Pump
Timing Belt
Water Pump
Piston Ring Set x 4
Honda-Bond
Thermostat & Gasket
Do you plan to upgrade the cams? If so....upgrade outer valve springs and LMA.</TD></TR></TABLE>
i was planing on all the oem parts being replaced and yes i am getting new cams and i also need new rockers i found 2 flat spots on my exhaust cam( not to happy about that)
and for the bigger injectors. i will be getting the Walbro 255LPH Fuel Pump and then a new ECU chip for the new setup should i get something else aswell??
Old Oct 3, 2006 | 03:19 PM
JDM_EK_621's Avatar
Default Re: started a parts list for my new motor i am building this winter (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">New Rod and Main bearings along with the thrust washers </TD></TR></TABLE>
thanks added to the list
Old Oct 3, 2006 | 03:20 PM
JDM_EK_621's Avatar
Do you plan to upgrade the cams? If so....upgrade outer valve springs and LMA.[/QUOTE]
question why just the outer valve springs and would i just get oem LMA's
soeurm
21
Apr 21, 2006 10:52 AM
XEF-9X
Mar 4, 2004 02:20 PM
compwc18
Feb 8, 2004 06:27 PM
prdtr15
Aug 19, 2003 06:44 AM
