What ECU do i use to bar'd a b16a2 into an obd2a chassis???
Just like the topic says, i was wondering what ecu can i used to bar'd a b16a2 into my obd2a EK?
Thanks in advance
Thanks in advance
Use the 99-00 civic si (p2t) ecu. If you have to buy a conversion harness to convert from OBD2a to OBD2b then thats what you gotta do. I have a 2nd gen JDM b16a in my 98 ek and repinned my 98 engine harness and added the correct plug from a 99 civic engine harness. So I have a custom 98 lx engine harness with the ecu plugs from a 99-00 civic . And i'm running a 99-00 si ecu, with no probs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadriver »</TD></TR><TR><TD CLASS="quote">Use the 99-00 civic si (p2t) ecu. If you have to buy a conversion harness to convert from OBD2a to OBD2b then thats what you gotta do. I have a 2nd gen JDM b16a in my 98 ek and repinned my 98 engine harness and added the correct plug from a 99 civic engine harness. So I have a custom 98 lx engine harness with the ecu plugs from a 99-00 civic . And i'm running a 99-00 si ecu, with no probs.</TD></TR></TABLE>
In order to get my motor bar'd into my chassis i don't i can use a jumping harness because the ref will check to see if i am using the correct ecu for the car.
Thanks for the info though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparco562 »</TD></TR><TR><TD CLASS="quote">
Thanks for the info though</TD></TR></TABLE>
i think that only applies if you were trying to use an older ecu, like an OBD1 P30/28
cage smith
Jun 17, 2012 06:09 PM
i2ishift
Jun 4, 2009 03:38 PM
