Setting vafc to stock settings how??
Does anyone know how to set the vafc back to stock settings??? Like no leaning or riching up the fuel and setting the vtec cross over point and throttle and stuff like that????? Is it that setting called Initialize??????? Or I can just look at whatever everything that is not 0 (as in ZERO) set it all to 0????? Thanks for all the help. I would like to do this better than removing my whole vafc unit for the stupid state ref.
If you initialize then you've gotta go back through the setup. Set number of pistons and the type of throttle position sensor. It's better to go back through each fuel setting per RPM and record the settings for low cam narrow throttle/wide Open throttle, then check High cam NT/WOT. They should look like graphs set between neg2 to neg5. Most vtec point are the same, but the vafc splits it up into in and out. I think you set both to the same number for stock (not sure).
From the main screen goto->Setting->
and V/T Cont for vtec x-over points
or WideThr
or Narr.Thr
V/T Unmt should be empty and all others should have no settings, but check.
or WideThr
or Narr.Thr
IgniteTeg
May 2, 2002 03:00 AM
