Checking spark strength
Old Oct 2, 2006 | 06:13 PM
vinuneuro's Avatar
Default Checking spark strength
I'm having startability issues with my engine. Is it possbile to have weak spark? How do I go about checking?
Old Oct 2, 2006 | 10:32 PM
F20Cteg's Avatar
Default Re: Checking spark strength (vinuneuro)
Check your spark plugs. OR better yet just replace them, it cheap.
Also you might want to change the cap and rotor. All normal maintanence.
Old Oct 3, 2006 | 07:59 AM
thesmogman's Avatar
Default Re: Checking spark strength (F20Cteg)
check you local autoparts store for a spark tester. It has an adjustable screw that increases the length of the spark. You will plug this tool into the sparkplug wire and attach it to a ground.
Or you could find someone with an occillascope. (Spell checked but still doesn't look right)
Old Oct 3, 2006 | 09:17 AM
Chiovnidca's Avatar
Default Re: Checking spark strength (thesmogman)
You can just use an old spark plug. Lay it against the engine and crank it over. The spark should be a nice bright blue and make a snap noise. An orange spark may be a bit weak.
Old Oct 3, 2006 | 09:40 AM
vinuneuro's Avatar
Default Re: Checking spark strength (Chiovnidca)
When I layed the current plug close to the chassis, I could hear the spark, but it was def more of an orange color. Can the fact that the chassis is painted affect that?
Old Oct 3, 2006 | 11:19 AM
LowTec MOHawk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">When I layed the current plug close to the chassis, I could hear the spark, but it was def more of an orange color. Can the fact that the chassis is painted affect that?</TD></TR></TABLE> ya that will change it alot. just lay it to somthing on the engine like the p/s pump or a bracket thats bare metal
Old Oct 3, 2006 | 01:26 PM
Chiovnidca's Avatar
If you can hear it easily it's probably ok.
b20bFourDoorCivicLX
Mar 16, 2012 10:26 PM
KloC 95 EG
28
Feb 2, 2009 12:35 AM
eseries07
Honda Civic (2001 - 2005)
Oct 26, 2006 11:28 AM
trianglegreg
Oct 26, 2005 06:18 PM
mongoliandonuts
23
Jul 27, 2004 02:13 PM
