disabled the knock sensor
Yes, if you run a chipped ECU with CROME or Neptune & OBD2 to OBD1 conversion harness. Hondata & AEM would also work. However if you have no need for a tuneable ECU I figure this would be an expensive way around the KS, I'm assuming yours is broken.
KS run around 50 bucks on HT or ebay.
