Does 17x7 rims with a +45 offset fit a civic or integra?
Hi i wanna purchase some 17x7 wheels with a +45 offset for my integra or civic? and can someone please explain what offset is? I tried researching but cant find anything!!!
Thanks in Advance!!!
offset is whether how far your wheel will stick out or in...the higher the number the more it will tuck...the lower the number the more it will stick out........on a civic you want to be around 35mm or as high as 45mm depending on what year the vehicle is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">offset is whether how far your wheel will stick out or in...the higher the number the more it will tuck...the lower the number the more it will stick out........on a civic you want to be around 35mm or as high as 45mm depending on what year the vehicle is</TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22xcivic »</TD></TR><TR><TD CLASS="quote">Hi i wanna purchase some 17x7 wheels with a +45 offset for my integra or civic? and can someone please explain what offset is? I tried researching but cant find anything!!!
Thanks in Advance!!!</TD></TR></TABLE>
16x7 42 offset on my 00 GSR, and with a 205/45-16 no issues with rubbing, though the rear tires were damn close to rubbing on the outside in the rear when I was tucking tire. The higher 45 offset will be fine, as long as you don't try fitting crazy wide tires, or overly reduce the camber from lowering (push the top of the tire out). 205/40-17 for the Integra and some Civics, and you'd ideally want a smaller diameter for those Civics that came with smaller tires, but I can't find anyone who makes a 17" tire in the correct diameter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">
I can't find anyone who makes a 17" tire in the correct diameter.</TD></TR></TABLE>
what year is your car and what diameter are you looking for??????????
eg4usdm
May 14, 2006 09:45 AM
