m22x, bc 4 and jun 3????? on my eudm itr
Old Oct 2, 2006 | 02:51 PM
ti pat's Avatar
Default m22x, bc 4 and jun 3????? on my eudm itr
Hello i'm newbie here. I search a long time for know what will be better cams for my car, but i don't always found same result.
My car is running with a jdm header, test pipe, 12:1 RV and competch ice box.
A friend say me: The m22x will be better than jun 3 in all powerband.
Is it true?
And BC 4 has got a better powerband with the same top power than m22x????
Thanks a lot....
Old Oct 2, 2006 | 03:16 PM
black cx's Avatar
JUN III's, proven time after time
Old Oct 2, 2006 | 06:59 PM
Aquafina's Avatar
Default Re: (black cx)
M22X's have beat Jun3's in more than one setup.
Old Oct 2, 2006 | 09:55 PM
ti pat's Avatar
Default Re: m22x, bc 4 and jun 3????? on my eudm itr (ti pat)
Nobody have test this three cams on a 12:1 itr motor????
Other opinions??
Old Oct 2, 2006 | 10:04 PM
esohsee's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">M22X's have beat Jun3's in more than one setup.</TD></TR></TABLE>
i dont doubt the m22X's but is there any dyno sheets to prove that they beat jun 3's?
Old Oct 3, 2006 | 02:42 AM
ti pat's Avatar
Default Re: (esohsee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esohsee &raquo;</TD></TR><TR><TD CLASS="quote">
i dont doubt the m22X's but is there any dyno sheets to prove that they beat jun 3's?</TD></TR></TABLE>
Yes i agree with you. It's the reason why I'm asking which is the best cam...
Old Oct 3, 2006 | 05:52 AM
UncleD's Avatar
Default Re: (ti pat)
The BC4 and the Jun3 have the same identical vtec lobe, but the BC4 has larger primaries. It might make more midrange than the Jun3, and will also idle rougher. The M22x is a bit larger than both of the cams mentioned above and has a near-stock idle. I don't have any dyno sheets of the M22x vs the Jun3's, we kinda shy away from "comparrisons" because so many different cams work better in different motors. If one cam won on a dyno, everyone would lable it as "the best cam," just like what happened with the header test. Rocket makes great power in great engines, the Jun3 is a proven cam profile time and time again, but it is very possible that the M22 would make you more power.
Old Oct 3, 2006 | 07:07 AM
ti pat's Avatar
Default Re: (clean rice)
Thanks clean rice. So bc 4 will have the best midrange, and the same top end power as the jun 3.
And the m22X the same midrange as the jun but more horse power at high rpm...
Is it ok???
Old Oct 3, 2006 | 08:18 AM
ti pat's Avatar
up
Old Oct 3, 2006 | 08:59 AM
xDicktonesx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">The BC4 and the Jun3 have the same identical vtec lobe, but the BC4 has larger primaries. It might make more midrange than the Jun3, and will also idle rougher. The M22x is a bit larger than both of the cams mentioned above and has a near-stock idle. I don't have any dyno sheets of the M22x vs the Jun3's, we kinda shy away from "comparrisons" because so many different cams work better in different motors. If one cam won on a dyno, everyone would lable it as "the best cam," just like what happened with the header test. Rocket makes great power in great engines, the Jun3 is a proven cam profile time and time again, but it is very possible that the M22 would make you more power.</TD></TR></TABLE>
the cam man comes through again. the jun3 is an expensive set of cams, but im saving my pennies becuase i dont want to say "i was gonna get those cams but i got these that are almost as good for my set up"
you guys know about this skunk2 deal, with them trying to flood the market? 375 toward their stuff for your cams? thats valvesprings, retainers and probably a shift **** to run with someone elses cams again
Old Oct 3, 2006 | 09:01 AM
Default Re: (xDEFTONESx)
you guys know about this skunk2 deal, with them trying to flood the market? 375 toward their stuff for your cams? thats valvesprings, retainers and probably a shift **** to run with someone elses cams again </TD></TR></TABLE>
and to help ya out a littlle bit ti pat, given the choice between the jun3 and bc4, i would an AM choosing the jun3 becuase of the SMALLER primary lobe due to the highway driving i do from time to time. if im not mistaken they have oem "R" primaries. this may sacrifice a little in the midrange but to me, it makes for a better cruising car below vtec.
Old Oct 3, 2006 | 10:41 AM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ti pat &raquo;</TD></TR><TR><TD CLASS="quote">Thanks clean rice. So bc 4 will have the best midrange, and the same top end power as the jun 3.
Yes you are correct, well, within theory yes. Assuming the motor will be able to take advantage of the larger primaries with the BC4 then it should have the better midrange and the same top end as the Jun3. The M22x will peak higher than either cam, or you could give the xx version of the M22 a try and get some more midrange, having a similar idle as the BC4. We've had good luck with the M22's in ITR motors, and like Deftones(awesome band btw) said, the Jun3's have type r-like primaries.....so freeway driving would be extremely easy on your VT. The M22x primaries are a bit larger than type r, but not by much.
Old Oct 3, 2006 | 10:56 AM
jeffsciv23's Avatar
i think clean rice always comes through on the cam questions. lol, he's like the cam moderator.
Old Oct 3, 2006 | 11:46 AM
Default Re: (jeffsciv23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffsciv23 &raquo;</TD></TR><TR><TD CLASS="quote">i think clean rice always comes through on the cam questions. lol, he's like the cam moderator.</TD></TR></TABLE>
that what ive been saying. sometimes ill see i cam question pop up and ill start my stop watch. i bet he will eb in the middle of a nice dinner with his GF and just jump up out of nowhere
"what wrong?!"
"someone on HT asked a cam question!"
&lt;dives out window&gt;
Old Oct 3, 2006 | 01:35 PM
jeffsciv23's Avatar
"what wrong?!"
&lt;dives out window&gt;</TD></TR></TABLE>
BWAHAHAHAHAHAHA
thats funny, but at the same time very true
Old Oct 3, 2006 | 04:25 PM
UncleD's Avatar
Hahahahaha I have no life!
Old Oct 3, 2006 | 04:31 PM
i just scored a b20 short block for a buck fifty. my original plans were 82x89 jun3s and headwork and steves ITBs but, now, its 2 liter and everythign ele remains. just means the motor will like VTEC 400rpms earlier i suppose.
4NLINE UNLIMITED
15
Feb 25, 2007 01:57 PM
The Si
Feb 22, 2007 04:24 PM
westfire25
Dec 8, 2005 04:25 PM
93jdmej1
29
Oct 7, 2004 05:47 PM
deez nuts
33
Jun 25, 2003 09:29 AM
