tranny rebuild
Old Oct 2, 2006 | 01:35 PM
93h22a1vtec's Avatar
Default tranny rebuild
So I am about to order parts to rebuild my tranny (h22). Im getting the full syncro set off of gearspeed, and their bearing and seal kit. I was just wondering if I should get the sleeve set as well. Money is tight and i dont want to buy it if i dont need it. My tranny was working when i took it out, however it was making a grinding sound due to one blown bearing casing (put little plastic shavings in tranny) and a few metal shavings due to my small 3rd and 5th gear grinds.
cliff notes: Is the sleeve set necessary for tranny rebuild?
Old Oct 2, 2006 | 02:52 PM
Default Re: tranny rebuild (93h22a1vtec)
bump anyone know?
Old Oct 2, 2006 | 03:37 PM
Flexmyrex's Avatar
so your only replacing the synchronizer rings, post pictures of the sleeve/hub. Depending on the condition its always wise to replace the whole syncronizer kit since you have it all apart- hub sleeve rings, basically you need the whole synchronizer kit.
lukehowell88
Nov 26, 2007 12:38 PM
93h22a1vtec
Oct 4, 2006 02:23 PM
dominate9
Jun 11, 2003 07:41 AM
tylerdurden
Feb 7, 2003 01:22 PM
