Suspension Techniques sway bar owners
Old Oct 2, 2006 | 01:19 PM
EF001282's Avatar
Default Suspension Techniques sway bar owners
I have a rear ST sway bar (green one) installed on my car among and I think that the shop that put it on might have put the brackets on backwards. the exhausts clearance sucks and the shop that installed it cut in to my exhaust to make the bar fit. What Im asking basically, is that the bracket has 2 circle holes on one side and 3 elongated holes one the other side. Which side mounts to the body and which side mounts to the endlinks of the swaybar? I have no instructions to look at, and I dont want to take the bar off until I know that its misinstalled. Right now the 3 holes are mounted to the body and the 2 holes are mounted to the bar. any pics would help, thanks again
Old Oct 2, 2006 | 02:20 PM
EF001282's Avatar
Default Re: Suspension Techniques sway bar owners (EF001282)
bump
Old Oct 2, 2006 | 02:38 PM
Outsane's Avatar
green sounds like progress rear anti-sway bar not st.
Old Oct 2, 2006 | 02:39 PM
WH0R3nEF9's Avatar
You posting pics would help. I had the st 22mm bar on my crx with 2.5inch exhaust and it cleared fine...it should clear. And why the hell would they cut into your exhaust?? Smells fishy!
Old Oct 3, 2006 | 04:59 PM
EF001282's Avatar
Default Re: Suspension Techniques sway bar owners (1SiKTeG)
should have pics on thursday
Old Oct 3, 2006 | 05:59 PM
LightWeightED8's Avatar
Default Re: Suspension Techniques sway bar owners (Outsane)
Old Oct 3, 2006 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">green sounds like progress rear anti-sway bar not st.</TD></TR></TABLE>
ST recently went to green
Old Oct 4, 2006 | 12:30 PM
CoryB's Avatar
The side with the slotted holes mounts to the body. The round holes are for the swaybar bushing mount.
Old Oct 4, 2006 | 12:35 PM
88 rex's Avatar
Default Re: Suspension Techniques sway bar owners (LightWeightED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LightWeightED8 &raquo;</TD></TR><TR><TD CLASS="quote">
ST recently went to green</TD></TR></TABLE>
Yuck.
Old Oct 4, 2006 | 12:42 PM
Furyof4's Avatar
Default Re: Suspension Techniques sway bar owners (88 rex)
The side of the bracket with two holes bolts to the shock. If you'll notice it has a lip welded to it that keeps the bracket from turning when bolted to the shock.
I have the same problem with it hitting my exhaust. I love this world sport but its it just doesn't fit.
Old Oct 4, 2006 | 03:10 PM
EF001282's Avatar
Default Re: Suspension Techniques sway bar owners (Furyof4)
ST recently went to green</TD></TR></TABLE> I was pretty sure it was ST.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">The side of the bracket with two holes bolts to the shock. If you'll notice it has a lip welded to it that keeps the bracket from turning when bolted to the shock.
I have the same problem with it hitting my exhaust. I love this world sport but its it just doesn't fit. </TD></TR></TABLE> I have the world sport too, and the way they made it fit the top of the exhaust tip is starting to rub on the bumper and the muffler itself is a little ****-eyed
Old Oct 4, 2006 | 05:12 PM
b16_madman's Avatar
help ya?
Old Oct 4, 2006 | 05:59 PM
EF001282's Avatar
Default Re: Suspension Techniques sway bar owners (b16_madman)
thanks for the pics. Thats the bar that I have but I painted it black to camo it a little, b16_madman do you have a pic of the other side by any chance?
Old Oct 4, 2006 | 07:03 PM
trrbl1bmx's Avatar
sounds like they installed it weird. because i installed mine upside down the first time. either the sway bar it self is upside down or the brackets are backwards.
Old Oct 4, 2006 | 07:57 PM
1320spTurtle's Avatar
Default Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">sounds like they installed it weird. because i installed mine upside down the first time. either the sway bar it self is upside down or the brackets are backwards.</TD></TR></TABLE>
i almost did the samething too, but i just paid attention to the directions to make sure i had it the right way. the hardest part was getting on the endlinks while the car was in the air
Old Oct 5, 2006 | 01:49 AM
trrbl1bmx's Avatar
after installing it on a few different cars, i found it pretty easy to install on the ground, and then put it up under the car, that way all you have to do i bolt it to the frame, and to the lca's ( of course leave everything loose, and all you have to do it go back and tighten everything. its always harder to work upside down, or backwards.
Old Oct 5, 2006 | 04:35 AM
Autoworks's Avatar
Default Re: (p00n)
A shot of mine
I don't know if that pic is helpful to you or not.
Old Oct 5, 2006 | 08:21 AM
godofcheese's Avatar
Default Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">A shot of mine
I don't know if that pic is helpful to you or not.</TD></TR></TABLE>
Very nice LCAs. Mine looks identical to that, except it is red. I had no problems installing on the ground.
Old Oct 5, 2006 | 09:14 AM
bunburyd16y's Avatar
just a comment: nice suspension upgrades under there
Old Oct 5, 2006 | 10:41 AM
theinfamouskonrad's Avatar
Default Re: (bunburyd16y)
looks like they installed it right. If you install the sway bar upside down, the sway bar will be touching the bottom of the car. Here's a pic of mine
KevinEF7
Jul 6, 2013 09:36 AM
Slamed2Fug
Mar 11, 2004 01:47 AM
moridin2004
Jan 10, 2003 01:44 PM
R91Si
Oct 12, 2002 08:36 AM
