help with megan header / blown gasket
Old Oct 2, 2006 | 01:05 PM
busyychild's Avatar
Default help with megan header / blown gasket
well i had a megan header install on my lude the other week. and not a week goes by and i start hearing a weird sound. the gasket between the exhaust manifold and the downpipe blew. My mechanic said that it was due to the uneven machining by megan. He suggested putting 2 gaskets and lots of high temp silicon in there to solve the problem. I called megan and they said that it was due to the torqueyness of my car, it having high miles and all (142,xxx). they suggested following the torque pattern when reinstalling the gasket. front bolt, than the rear two all 1/2 way then torque down in the same pattern.
Im left wondering what to do. Is there anything you guys can suggest aside from just welding the two pipes together to solve the problem once and for all. I dont want to go through all of the work to put in 2 new gaskets only to have it fail a week later. Thanks!
this is what the gasket looks like, (note, this is not the actual gasket)
Old Oct 2, 2006 | 01:13 PM
kulrevon's Avatar
Default Re: help with megan header / blown gasket (busyychild)
you have to torque them down. and torque them again later. I had a problem with a different company but same design. I had the hardest time trying to find the gasket. Did you just get it from megan? I ended up tightening the bolts twice once when I installed and once a week later or so.
Old Oct 2, 2006 | 01:59 PM
busyychild's Avatar
Default Re: help with megan header / blown gasket (kulrevon)
i am getting them through megan, i think they are 5 bucks a piece. so torquing the down again solved your problem, cuz i guess i will try that, i just dont want o have to do it every week. i am hoping 2 will work.
Old Oct 2, 2006 | 02:53 PM
E-Money's Avatar
this does not make me feel confindent about installing my megan header for my lude. I bought it new/open box from a fellow user of H-T. And the the primary gasket was all bent up from the shipping. So i flatened with weight on top of it. Possibly getting it installed tomorrow from my mechanic.
Old Oct 2, 2006 | 03:58 PM
WhiteBB2's Avatar
Default Re: help with megan header / blown gasket (E-Money)
I too am putting my megan header on my h22a. It should be done by wednesday, I had to get a tranny rebuild and the mechanic is throwing it on there for me. Hopefully it was just a fluke. Cause all the research I did, No one else had this problem.
Old Oct 2, 2006 | 04:04 PM
Hondaen's Avatar
Default Re: help with megan header / blown gasket (WhiteBB2)
The studs and nuts used on this header is crapy.
Drill out and use som real stainless nuts and bolts, then tight it firmley..
Old Oct 2, 2006 | 06:29 PM
E-Money's Avatar
Default Re: help with megan header / blown gasket (Hondaen)
the hardware that comes with the kit looks fine to me, but you get what you pay for...
Old Oct 3, 2006 | 09:18 AM
godslayer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busyychild &raquo;</TD></TR><TR><TD CLASS="quote">well i had a megan header install on my lude the other week. and not a week goes by and i start hearing a weird sound. the gasket between the exhaust manifold and the downpipe blew. My mechanic said that it was due to the uneven machining by megan. He suggested putting 2 gaskets and lots of high temp silicon in there to solve the problem. I called megan and they said that it was due to the torqueyness of my car, it having high miles and all (142,xxx). they suggested following the torque pattern when reinstalling the gasket. front bolt, than the rear two all 1/2 way then torque down in the same pattern.
Do not use 2 gastkets. That is just asking for more trouble later as exhaust WILL eventaully break through between the two gaskets causing a bad leak. GEt a new gasket and torque them correctly and to the appropraite values. DO NOT just tighten one bolt ALL THE WAY, then another, then another, and so on. You probably warped the union plates by unevenly tightening bolts and crushed/tore the gasket casuing your leak.
Old Jan 27, 2018 | 10:42 PM
starbai's Avatar
I'm dealing with this now too.
Is it possible to just buy a really thick gasket and cut it to size and sandwich it all together?
I'm thinking about throwing this whole **** in the trash, bite the bullet and just buy a DC header/downpipe.
Old Jan 28, 2018 | 07:52 PM
TimiK's Avatar
10 Year Member
Why to waste your money into DC/megan since theyre just oem replacement parts? You can get as good no name ebay header if you don't have your stock one left
Chris404
Apr 20, 2013 11:35 PM
krysted9354
Dec 17, 2008 05:45 PM
jonnybadboi9
May 8, 2008 06:16 PM
jay di em02
Jan 28, 2007 11:00 AM
b16a1civichb
Nov 30, 2002 07:49 PM
