Proper way to atatch a rod end to a Streamline tube.
Hopefully you can understand what i am talking about in this picture. \/
http://www.gurneyflap.com/Reso...9.jpg
Is there a company or a somewhat easy way to make a nice looking transition from a tube to a rod end? Anything similar to this? \/
http://www.aedmotorsport.com/T...s.htm
Thanks in advance!
Thanks in advance!
the site you posted is exactly what you need...... if you want to compare you can also check http://www.speedwaymotors.com
i ordered a bunch of rod ends and jam nuts from them straight off the net and they were great with the shipping
speedway doesnt have the streamline fittings. chassisshop.com sells ends specifically for streamline chromoly tubing.
I'm not sure if you can order the parts directly from Chassis Shop. If not, HRP is a seller of Chassis Shop parts. I had to special order the hex shaped tube adapters. They came fairly quick.
6SPD_EK
Suspension & Brakes
Apr 18, 2008 09:07 PM
