all disc brakes
ok, this might sound dumb to you guys but which are the trailing arms that i could put on my crx dx to convert it to all wheel discs, i think it might be the 90-93 integra but i dont remeber for sure.. thanks alot
ok cool, will the big arm buhsing transfer over cause i happen to have new ones on my stock arms, also im prolly going to have to change the brake lines aswell?, also the si ebrake cables are off a 90 crx si or integra?
http://www.performanceforum.co....html
No it will not transfer. I ask why you want disc brakes other than for looks. Performance of disc and drum isn't enough of a reason to change them. Just FYI.
i guess for looks cause it would look nice if i would get a set of rims and ditch the steely's, but i actually happened to think they would stop faster, but thanks maybe ill reconsider this for now, but while we talk about the rear end the trailing arms i see for sale everywhere are they worth purchasing, or should i say wat things can i do to help my handling i currnetly got coilovers
The best TA bushing to get are the ones from Honda or Mugen (ie Rubber). Especially for the street.
Before we can tell you what will help give us a run down of what you have, shocks, coilovers, lbs springs, sways, etc....
as far as i know everything on is the stock suspenison except coilover's and rear control arm(energy suspension) and trailing arm buhsings(honda oem), i have a b16 swap which makes the front a little heavier, the front rides good but because of the stiff coilovers the backend hits bumps and bounces me all over the place occasionally smacking my head from roof..haha i was considering new rear struts soon
What kind of coil overs are they. If they are bouncing you all over they sound like some cheap eBay knock offs and you are most likely better off to replace them. Also I would question how low your car is. If is to low it will also make you suspension useless.
yea they are cheap i got them from a buddy new.. they helped handleing preetty good but the lighter rear end is super stiff.. the car really is not too low have them rasied as high as they go to i gues stock height.. where i live itd be foolish to lower it, to many potholes and shity roads,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 »</TD></TR><TR><TD CLASS="quote">yea they are cheap i got them from a buddy new.. they helped handleing preetty good but the lighter rear end is super stiff.. the car really is not too low have them rasied as high as they go to i gues stock height.. where i live itd be foolish to lower it, to many potholes and shity roads, </TD></TR></TABLE>
LOL...I'll vouche for the shitty roads in nepa...have had to replace several ball joints and all my shocks due to these horsetrails they call roads
haha, i have the springs cuase my stock fornt coil springs snapped due to bumpy ness, i live on a mtn not to far form allentown(whihc has decnet roads) and the roads up here guess due to extreme wether are just plain horrible, anyone with a lowered vehicle from this region knows wat i mean, hate driving my car cause of them, dont want to put more wear on it then needed
IMO you need to forget about doing anything with your brakes and invest in a decent suspension setup. I would looking to a full coil over or some sleeves such as Skunk2 or Ground Controls in combination with Tokico Illumas or Koni yellows. After you get your suspension under control then look at doing your brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 »</TD></TR><TR><TD CLASS="quote">90-00 integra
89-00 civic
??</TD></TR></TABLE>
you can use trailing arms from any of those years for the rear disc conversion
89-00 civic
ok sweet well im still going to the rear discs cause when i rip the suspenison apart its a few more bolts to change the arms.. ill get it all done at once.. what do you mean by Ground Controls in combination with Tokico Illumas or Koni yellows?, sry just becoming a honda guy not used to some of terminology, i was more into my camaro for a while but gas prices stopped that real fast.
is it possible to change the rear coilovers, due to the fact the front rides and handles perfect but you can feel the back end kick up when hitting bumps. i mean if they all must go they will all go but wat id liek to do is save on some cash since i just recently put in the b16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 »</TD></TR><TR><TD CLASS="quote"> is it possible to change the rear coilovers, due to the fact the front rides and handles perfect but you can feel the back end kick up when hitting bumps. i mean if they all must go they will all go but wat id liek to do is save on some cash since i just recently put in the b16.</TD></TR></TABLE>
Anything is possible, but why have two different sets of springs/coilovers with different spring rates?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdxb16 »</TD></TR><TR><TD CLASS="quote">ok sweet well im still going to the rear discs cause when i rip the suspenison apart its a few more bolts to change the arms.. ill get it all done at once.. what do you mean by Ground Controls in combination with Tokico Illumas or Koni yellows?, sry just becoming a honda guy not used to some of terminology, i was more into my camaro for a while but gas prices stopped that real fast.</TD></TR></TABLE>
The Skunk2 Coil over sleeves. (You can get them cheaper elsewhere) http://www.skunk2.com/Merchant...unt=3
The Ground Control Coil over sleeves. http://www.nolimitmotorsport.com/groundcontrol/
These are the two coil overs that I would look at. In combination with these coil overs I would use the Tokico http://www.tokicogasshocks.com/products/illumina/ or the Koni's http://www.redshiftmotorsports...%29+2 That will make for a very good suspension setup. It is a good foundation to start with then you can do your sway bars later if you desire.
Also do not cheap out on suspension cause you will end up where you are right now with crappy suspension.
Also it does not ride and handle great if the back end is moving around
I had the Skunk2 coilover sleeves when I first got my B16 swap in my CRX and I was totally unsatisfied. I would not recommend them, my car bounced more than Pamela Anderson's tittays on Baywatch.
Went with Progress springs for an EF with a B-series swap and I love them! I also have Tokico Illuminas, they are great!
pocketjs
Apr 14, 2009 11:06 AM
