Distributor and ECU
So, I just found out, that my distributor and ECU are fried so i need to find a 93 JDM h22 distributor, unless there is an alturnative? and also a p13 ecu or chipped ecu... any help? Thanks.
BTB, i heard that the 99-00 Civic Si distributors work w/ the JDM h22... true or not?
parts needed:
JDM h22 obd1 Distributor (internal coil)
OBD1 Manual p13 ECU
parts needed:
OBD1 Manual p13 ECU
type in h22 distributor in the search enginge. i forgot the options for doing it though. there were several post on what you could do. you might have to click the archieve post though. ebay sells a few jdm distributors. one of the best was distributor king seller. i almost bought one but i found my problem.
hmmm... thanks for the info, but does anyone know if a 99-00 Civic Si distributor will work on my JDM h22???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flight50 »</TD></TR><TR><TD CLASS="quote">type in h22 distributor in the search enginge. i forgot the options for doing it though. there were several post on what you could do. you might have to click the archieve post though. ebay sells a few jdm distributors. one of the best was distributor king seller. i almost bought one but i found my problem.</TD></TR></TABLE>
